95 Jeep Cherokee Catalytic converter removal and possible CEL - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > 95 Jeep Cherokee Catalytic converter removal and possible CEL
Poison Spyder from CCOR!8.8 Swap Kit w/ TRUSS for JeepsDana 30 Truss for your TJ, LJ, ZJ, and XJ
Closed Thread
Unread 01-10-2010, 12:25 PM   #1
BlackStig
Can I Hypothetically remove the cat on a 95 XJ with out having the CEL light come on?
If i do Hypothetically remove the cat and and O2 sensor How could Bypass it so the CEL does not come on?
BlackStig is offline
Unread 01-10-2010, 12:27 PM   #2
lowicz96
1995 XJ Cherokee
It illegal to remove the cat!!
But it wont throw a CEL. 95 only has 1 O2 senor and it before the cat. If you do remove it, it will backfire occasionally
Project/DD - 95' Cherokee Sport, 2 Door, Converted to 4x4, AX-15, NP231, Black and lots of other goodies
88' Cherokee Limited - RIP
Sold - 96' Cherokee Sport 4x4, 2 Door, AW4, NP242, Its the girlfriends now!!
lowicz96 is offline
Unread 01-10-2010, 12:40 PM   #3
Cherokee-at-16
Hey im trying to replace my cat and does anyone know if you can take it out without removeing the rest of the exhaust system.......Right now im just driveing with the clamps off hopeing it will start to fall off(the cat that is)its rusted on i think
Cherokee-at-16 is offline
Unread 01-10-2010, 12:45 PM   #4
rustywrangler
Got my eye on you.....
rustywrangler's Avatar
Sawzall or hack saw will work just fine. Then just use some clamps and adapters and you are set. IF you are welding it in, alot of time it is better to replace the muffler as well due to rust.
Congenital Heart Disease is a reality for me, BOTH of my children have it. Please read up and become aware for future generations
Lydia Ann-Acquired 08/05/05 Open Heart surgery 08/10/05
Jacob Patrick-Acquired 01/17/08 Open Heart surgery 02/15/08
rustywrangler is offline
Unread 01-11-2010, 02:11 PM   #5
Cherokee-at-16
What adapters???
Unread 01-11-2010, 02:37 PM   #6
talentjeep
1987 XJ Cherokee
talking about cat removal can get you banned.
You need one to make air pressure right for O2 sensor anyway and you need your O2 to help your computer make the rest of the correct emissions decisions. It's not a 1965 mustang it's a Jeep and it needs it's eyes and ears!
'87 XJ Pioneer with 32" KM2s, etc.
talentjeep is offline
Unread 01-11-2010, 06:03 PM   #7
Solidsyko
1995 XJ Cherokee
idk...I had my cat blow out into my muffler, went about 6 months before I could afford a new cat. During that time my highway mileage was still around 20, but my around town went down to 15ish. New cat in and my city driving is back to 17ish. Maybe it's coincidence...but the cat seemed to effect how the engine ran at least a little around town.
Solidsyko is offline
Unread 01-11-2010, 06:05 PM   #8
leftlanetruckin
XJ on 37's
leftlanetruckin's Avatar
What adapters???
There are adapters to go from one size of tubing to another. If your exhaust is 2.5", and the cat is 2.25", there are adapters to sleeve it down making it easier to install aftermarket cats etc.
Martin
1998 XJ on 37's.JK Rubi axles with chromo shafts and ctm's, 4:1 transfer case, etc etc etc.The Cherylkee....
2003 Range Rover HSE, 4.4 Quad Cam.
1998 Range Rover 4.6 HSE
2000 4.7 4WD WJ with a rebuilt motor.
4.3/700r4/new frame buildup (YJ)....
http://www.jeepforum.com/forum/f12/swap-offically-underway-324622/
Years to gain the hands on experience, and offer it freely.
Minutes to gain the knowledge from the internet, and quote it just as freely.
Choose wisely!
leftlanetruckin is offline
Unread 01-12-2010, 07:11 AM   #9
WrenchedXJ
1989 XJ Cherokee
Pre-96, at least here in NC is safety inspection only, but that cat converter, muffler, all that stuff is a visual inspection. Plus on non-OBD-II vehicles, there is no O2 sensor after the cats, only before, so no CEL SHOULD be thrown.
On my old Bronco 2, of course the lovely ford engineers had two cats run in series, the PO of it had chopped the muffler off and the stuffing in the rear cat(metal mesh) was blocking the exit, as a quick fix to get her running well again, I got all that stuff out, and noticed that the front cat was clogged as it would glow red. Took a hammer drill and emptied it. With this all said, this was a TEMPORARY fix and should not , e permanent. The intentions were to put a High Flow cat on, but then I found my gem of a Cherokee and traded. Typically, car engineers design the car to run with a cat, removing one can harm the vehicle in the long run, not to mention its illegal.
WrenchedXJ is offline
Unread 01-22-2013, 02:05 PM   #10
wildmustard
I live in an apparently cat-free zone. At least all research I have done has turned up no laws that prevent removing it. Initial licensing for vehicles previously registered in my jurisdiction only requires a safety check (lights, signals, brakes, wipers, etc.) We do not ever have to submit to emissions testing. My old 93 XJ came out of storage with rust holes in both cat and muffler. A DIY replacement muffler was $60. I replaced the cat with 2 feet of straight pipe, with one end expanded by the muffler guy - $5. A couple of clamps - $5 - and presto! Beautiful solution. Nice rumble. No issues. Mileage or power differences? Who knows. Lets face it, an XJ is not gas-mileage monster, and without a dyno power is subjective.
Note that US EPA and other statements about removal of cats being illegal simply do not apply in Alberta, Canada.
I do apologize for my post, and will remove it if asked. Yes, the forum rules do indicate that breaking a law is not be discussed. However, I will point out that all indications are that I have not broken any laws.
wildmustard is offline
Unread 01-22-2013, 02:26 PM   #11
dagr8tim
dagr8tim's Avatar
1997 XJ Cherokee
Originally Posted by wildmustard View Post
I live in an apparently cat-free zone. At least all research I have done has turned up no laws that prevent removing it. Initial licensing for vehicles previously registered in my jurisdiction only requires a safety check (lights, signals, brakes, wipers, etc.) We do not ever have to submit to emissions testing. My old 93 XJ came out of storage with rust holes in both cat and muffler. A DIY replacement muffler was $60. I replaced the cat with a 2 feet of straight pipe, with one end expanded by the muffler guy - $5. A couple of clamps - $5 - and presto! Beautiful solution. Nice rumble. No issues. Mileage or power differences? Who knows. Lets face it, an XJ is not gas-mileage monster, and without a dyno power is subjective.
Top of page #2:
http://www.epa.gov/compliance/enforc...hsysrepair.pdf
Jeeping - The art of getting dirty & going broke while slowly heading nowhere, and taking all day to do it.
97 XJ SE - DD/Light Trail Rig - The War Wagon
75 CJ5 with a badly chopped CJ7 Tub - Pandora
dagr8tim is offline
Unread 01-22-2013, 02:53 PM   #12
Pats94
I've read that before to follow the letter of the law installing high flow cats unless certified as direct replacements are illegal. Air intake and muffler enhancements violates epa certified noise levels.
You all in violation so park them.
If its stock it sucks and if it scares the hell outta ya its just about right!
Pats94 is offline
Unread 01-22-2013, 08:01 PM   #13
dmill89
1995 XJ Cherokee
Originally Posted by dagr8tim View Post
^ wildmustard is in Canada, the EPA being a US gov. agency has no jurisdiction there so this doesn't apply to him. I'm not sure what if any restrictions exist in Canada as far as modifying or removing the cat.
dmill89 is offline
Unread 04-02-2013, 10:29 AM   #14
Purcell69
1986 XJ Cherokee
With regard to the OP's question, you can replace the two wire O2 sensor with a heated four wire sensor, connected to keyed 12v power, to help tell the computer what to do. From the other posts, it seems that it will not throw a CEL either way. I have a 1995 parts XJ that I pulled the exhaust off of and I have driven it around my property without getting a CEL, but then it was only run for a few minutes.
-Joe
Purcell69 is offline
Unread 04-02-2013, 12:29 PM   #15
mschi772
mschi772's Avatar
Regardless of your local laws, discussing topics like this are not allowed here because the JF does not want to facilitate dispersal of any info of this type to people who do have laws against it (that's my interpretation of one of the reasons for the forum rule anyway).
Even though you don't have any laws prohibiting it, you gain nothing by removing the cat (cats aren't restrictive and have an utterly negligible effect on performance). Cats last a long time and are relatively cheap for their lifespan, so if you have a cat problem, fix it. O2 sensors do more for your Jeep than just monitoring the cat, so it's in your and your Jeep's best interest to maintain the O2 sensors as well. By removing the cat, you only serve to pollute our air.
2002-2009 1983 Chevy El Camino
2009-2011 1994 Cadillac Eldorado ETC
2011-Pres 1996 Jeep Cherokee Country
Biologist
Dog trainer
Mountain biker
Gamer
Jeep owner
mschi772 is offline
Closed Thread
