95 Jeep Cherokee 4.0 Issues - JeepForum.com
post #1 of 4 Old 07-02-2013, 01:01 PM Thread Starter
Otep7734
First off, This is my 1st post so I'll Squeeze in some introductions
I'm Will, Recently returned from Afghanistan via the US Army. While I was away my dad bought a ford (BOO!) so in return I got a semi-Free Jeep. The Exhaust Manifold was cracked and the O2 Sensor was fried so in return to buying and fixing that, I received a free beat up jeep.
However, being in the Army, I had some pay issues overseas so I'm playing catch up with finances and still working on my jeep when I can afford it (time and money)
Current Issues:
Timing feels/Sounds off (Advanced a few degrees?) my NOX where high and it sounds like it is off....
AC Fan is shorting out (If i turn on the AC at all, it runs like a champ for 3 minutes or so and then abruptly the Jeep dies...)
-Planning on getting a junk yard one that dose not smell like burnt resin when I get a chance, or a bran-spanking new one if i get the cash.
Driver's Side Front Door the top hinge is free floating. It looks like it was welded at one point (Poorly at that) but since then broke free.
-planning on Re-welding it until i get a more permanent fix lined up.
Power Steering leaks from the actual gear box (the one with the worm gear)
-Currently adding Power Steering Stop-Leak Fluid (Cant afford a new box at the moment)
Trans leaks from what I suspect is a slight tear in the rear seal
-Currently adding Lucas Trans Stop Leak fluid due to lack of funding and time constraints....
So any Sugestions tips or tricks you guys/gals know? or even the "you got a crappy jeep comment".
Otep7734 is offline
post #2 of 4 Old 07-02-2013, 07:24 PM
bobthecatkiller
For free that's damn good deal get some pics up
"****, I might **** around and bring the Jeep back No doors on it, flexin' with the seat back"
bobthecatkiller is offline
post #3 of 4 Old 07-02-2013, 07:38 PM Thread Starter
Otep7734
I'll Post some pictures of it in the morning; along with a few WTF things I've noticed
Otep7734 is offline
post #4 of 4 Old 07-03-2013, 12:17 AM
bobthecatkiller
Every vehicle will have its problems, mine had rotten m&ms with bugs all over them under the carpet, and my previous owner "fixed" the trim on the driver side door. His fix was a dry wall screw:/
