95 cherokee sport gas and spedometer gauges not working - JeepForum.com
post #1 of 7 Old 10-26-2008, 08:07 AM Thread Starter
skierdude52689
1997 XJ Cherokee
for a like 2 weeks my spedometer would randomly go up and down when i hit bumps the needle would go up and down and then return to the regular speed it was at. now the gas and speed don't work at all. i only have a speedomete and gas gauge, nothing else.
my question, whats the problem, what's the cheapest way to fix it.
*edit* i checked the fuse box and the fuse for the gauges *number 17* is fine, checked continuity and it works. so maybe a ground?
skierdude52689 is offline
post #2 of 7 Old 10-26-2008, 09:30 AM
STG
2006 WK
Good question...my gauges have been going haywire lately, too - but with me it's the oil pressure and engine temp gauges. I think the issue is a ground in mine, but I've not yet checked.
STG is offline
post #3 of 7 Old 10-26-2008, 10:10 PM Thread Starter
skierdude52689
1997 XJ Cherokee
*edit* the check engine light just turned on as well as the battery light, checked all fuses and there all good. its a new battery as of a year and a half ago.
seriously any help would be great!
post #4 of 7 Old 10-27-2008, 02:56 PM
xjcowboy01
Hey man I had a problem with the gauges on my 93 and it turned out to be ground wires. On the passenger side of the engine and just behind the distributor is where they are. There are three of them in total and they all control your gauges. Fix all those wires and you should be good to go. That would also explain the intermittence of the problem. The wires probably werent broken all the way at first but now they are. Give it a shot.
Live for those who have died for your freedom.
xjcowboy01 is offline
post #5 of 7 Old 10-27-2008, 08:41 PM
scruff_08
I had a problem on my '96 that the fuse were good but the fuse panel itself was melted on the back, you could barely tell but if you looked at the socket for the gauge fuses it was burnt out and would only work occasionally
scruff_08 is offline
post #6 of 7 Old 10-28-2008, 11:18 AM
warrior_oh58d
1991 XJ Cherokee
I'm having a similar problem on my '91 but none of my guages are working at all, i am also getting some crazy hesitation on start up, it seems to get better when the engine warms up but now it's doing it all the way through the drive to wherever i'm going
warrior_oh58d is offline
post #7 of 7 Old 10-28-2008, 12:59 PM
iflyabeech
iflyabeech's Avatar
try moving the wire bundles above your feet/under the steering wheel. I have had a problem of all my gauges going to zero intermittently for a while. usually a kick under the dash and they come back to life...i have no idea what is coming loose under there, but a little kick or two does the trick....I update my 99 XJ gauges from the idiot lights to mechanical gauges and now when this happens, I get "No Bus" on the odometer...I am not sure if this is your problem in the 95 or not, but thought it might help.....you can also do a forum search on this!
1999 XJ Cherokee SE 4dr 4x4
4.0L I6, AX15 5-Speed Tranny, NP231, Dana 30 high pinion Front, Chrysler 8.25 Rear, 3.07 gears, Quadretec HD leaf springs
iflyabeech is offline
Gauges Working Intermittently - 1997 Cherokee jrennard3 XJ Cherokee Technical Forum 4 12-02-2014 05:51 PM
99 Cherokee Sport 4.0L - All gauges failure searcherrr XJ Cherokee Technical Forum 6 07-02-2013 05:02 PM
96 Grand Cherokee Limited - no gauges working harryash XJ Cherokee Technical Forum 1 02-06-2010 04:05 PM
1992 cherokee laredo speed/tach/fuel gauges not working? ChucksJeep XJ Cherokee Technical Forum 0 02-24-2008 08:12 AM
97 Cherokee Sport - passenger window not working pharunk XJ Cherokee Technical Forum 2 01-14-2008 04:04 PM
