'95 Cherokee Sport(2DR) Tail/Running Lights - JeepForum.com
post #1 of 14 Old 05-03-2011, 03:47 PM Thread Starter
abidingcrawdad
1995 FSJ Cherokee
Recently I towed a trailer for a friend, ever since fuse 15 has been blowing(takes about 10-15 minutes to blow) I used the trailer wires on the tow-job, they hadn't ever been used during my ownership.
So; now the tail lights and running lights won't work, I replace the fuse and they work, but I don't get what the deal is.
It looks like some one who had the Jeep before me replaced the trailer plug(shoddily) so I snipped that off and sealed the wires, put a new fuse in; it blew again.
Headlights, Brakelights, and turn signals all work fine; I'm stumped.
I would greatly appreciate any help at all, getting a bit frustrating
abidingcrawdad is offline
post #2 of 14 Old 05-03-2011, 07:29 PM
keepishop
1989 XJ Cherokee
Try a bigger fuse, maybe a 20?
As things get old the wires corrode and cause more resistance. My power seats in my old jeep came with a 5, but would blow the fuse every now and then. A 10 fixed it.
If it was a full on short circuit, the fuse would be blowing instantly anyway.
Current: Black 89 limited, dakota bastard pack, zj coils, 1.5" lift, open cooling swap,
Rest in Pieces: Red 1990 cherokee dana30/8.25 - v8 zj coils & s10 bastard pack 2.5" lift - 31x10.5r15 tires - v8 zj tierod
Originally Posted by talentjeep View Post
Bleed or Quit.
jf irc @ irc.freenode.net #jeepforum
keepishop is offline
post #3 of 14 Old 05-23-2011, 02:58 PM Thread Starter
abidingcrawdad
1995 FSJ Cherokee
I tried a bigger fuse, it keeps blowing, online it says I should have a 15(I've seen...) but mine's always had a 20. I tried a 25 and it blew anyways.. It's been almost 2 months, don't have money to bring it in so I have to do this myself.
I've checked the tail/driving light sockets and bulbs, everything seems alright there..
Anything else I could try? thanks a million
post #4 of 14 Old 05-23-2011, 10:40 PM
keepishop
1989 XJ Cherokee
Is it a uhaul (or whatever) tow harness, or a stock one? I know mine is connected with a bunch of hacky splices, yours might be too. Try just removing it.
Bleed or Quit.
post #5 of 14 Old 05-23-2011, 10:42 PM
sbxj
sbxj's Avatar
you've got a short somewhere
putting a bigger fuse in is the worst advice
'01 XJ 2DR Sport
'99 WJ Laredo, 4.0L with HID Retrofit
sbxj is offline
post #6 of 14 Old 05-24-2011, 11:24 AM Thread Starter
abidingcrawdad
1995 FSJ Cherokee
Right on sbxj, I'm trying what is recomended; ignorance, heh...
keepishop; it was just a regular crap-job trailer wire harness, I've already removed it and sealed the wires, still popping the fuse, it doesn't pop right away though.. it can sit and idle for a while, but when I drive it, it blows after about 5 minutes or less.
post #7 of 14 Old 05-24-2011, 12:12 PM
keepishop
1989 XJ Cherokee
Does it blow if you are idling and push the brake pedal?
Bleed or Quit.
post #8 of 14 Old 05-24-2011, 02:31 PM Thread Starter
abidingcrawdad
1995 FSJ Cherokee
nope, only when I'm driving it seems. while idling; I can hit the brakes, turn them off and on and it doesn't pop, when I start driving it doesn't take long at all
post #9 of 14 Old 05-24-2011, 09:17 PM
keepishop
1989 XJ Cherokee
Try popping out all of the bulbs and go for a quick drive. If it doesn't blow, then you have a place to start looking at the wiring harness.
I'm thinking maybe you have an exposed wire in the harness that hits body metal when you are driving.
Bleed or Quit.
post #10 of 14 Old 05-25-2011, 07:34 PM Thread Starter
abidingcrawdad
1995 FSJ Cherokee
tried that, and put in one bulb at a time; so now it's isolated to the passenger tail-light. replaced the socket, still popping though...
where is a likely spot it could be rubbing through? the insulation at the rear looks just fine, the wires are all happy.. driving me insane
post #11 of 14 Old 05-25-2011, 10:20 PM
keepishop
1989 XJ Cherokee
At that point, I would just give up and run wires from the driver side tail light to the passenger side. haha
Test the supply and ground wires on both sides and make sure they match. I bet they don't. Someone with more electronics know-how could probably tell you more.
Bleed or Quit.
post #12 of 14 Old 05-25-2011, 10:46 PM
sbxj
sbxj's Avatar
I recall having a short at the tailight in a '93 and it was where the rubber boot enters the body.
everything may look fine but it could be a small cut in a wire making contact to another wire. Have you exposed all the wires in the harness?
good luck!
'01 XJ 2DR Sport
sbxj is offline
post #13 of 14 Old 05-26-2011, 09:13 AM
bro-quo
1997 XJ Cherokee
I have a '94 2dr and was having the same problem. Kept blowing the fuse for turn signals, running lights and dash/gauge lamps every time i turned the ignition on while the headlamps, brake lights, and reverse lights were not affected. The issue turned out to be the trailer lamp harness and upon cutting it out and replacing it the problem was no more.
'94 2dr. (parted out =-[ )
DD '00 sport 230/75, stock, 30(open)/8.25(lsd)
DD '97 sport 235/70, .75" shackle rear, 30(open)/35(trac-loc)
bro-quo is offline
post #14 of 14 Old 05-26-2011, 01:33 PM
JWELK
If the fuse only opens when driving, I'm thinking something is getting hot. Check for wires that could be near the exhaust or chafing on the drive shaft.
To prove this, put the tail lights on w/o the engine running, you may need a charger or another car nearby to jump. Then let the engine idle and see if opens at this time. Purchase a "test socket with combo brake and tail lamp. Tack solder the black socket lead to one side of one your blown fuses. Solder a piece of wire to the other side of the blown fuse. Install the lamp in the socket and wrap one of the leads to the pigtail. Insert this device in the tail lamp fuse position. The test socket lamp should dimly light and the tail light bulbs should also light dimly. When the short appears, your test light will light normal and your taillights will go out. The taillight section of your test fixture will allow less current, the brake will allow more and both wires connected will allow even more current. Carefully wiggle the wire harness around until an observer tells you your test fixture has turned off. This procedure allows you to troubleshoot the circuit without going thru boxes of fuses. I have also substituted a small "sonalert" (back up alarm, but softer) for single person troubleshooting. The noise does get annoying after a very short while. As the lightbulbs limit the current flow, this prevents the penny in fuse box scenario.
Ever hear about the guy with a similar problem? This was in the days when they had glass fuses, at any rate he discovered that a .22 long rifle was a good substitute for a blown fuse. Worked fine for awhile. I understand it was only minor surgery to have the slug removed form his leg. I would imagine his ego has yet to recover.
Regards,
Jim W
That's what a Jeep is, you know. It's not just tires a tub and an engine; that's what a Jeep needs. Not what a Jeep is. What a YJ really is, is freedom.
CAPTAIN Jack Sparrow, Pirates of the Carribean
JWELK is offline
1995 , cherokee sport , driving lights , not working , tail lights
1989 Cherokee: Tail lights + Dash lights not working. Help please. BlackoutGO XJ Cherokee Technical Forum 10 06-11-2014 07:24 PM
1995 Jeep Cherokee sport tail light issue kaprosm XJ Cherokee Technical Forum 6 03-09-2011 07:30 PM
Running and tail lights Brew461 XJ Cherokee Technical Forum 6 03-08-2011 09:06 AM
1990 XJ No tail lights Running lights) and no dash lights Pistolspark XJ Cherokee Technical Forum 2 08-19-2008 08:29 AM
cherokee tail lights 95fatxj XJ Cherokee Technical Forum 3 04-02-2008 03:21 PM
