95' cherokee drivers side door top hinge broke - JeepForum.com
post #1 of 14 Old 08-21-2009, 07:06 PM Thread Starter
Demonangel
Bought a 95' Cherokee sport but the top hinge for the drivers side door broke off. need any ideas on how to fix this.
Demonangel is offline
post #2 of 14 Old 08-21-2009, 07:12 PM
Kettles
Weld it? Did it rip off on the body side? I hear that is not uncommon. Fastest fix is welding it back on. Or you can weld in a plate and convert it over to bolt on.
_=====o000o
//__l_l_,\____\,____
l_--\_l__l_/--|lllll|
_.(o)_)__.(o)_)--o-)_)
"Dee", a Patriot Blue 2001 Cherokee Sport 4.0L High-Output
"Live Free Or Die; Death Is Not The Worst of Evils." -General John Stark
Originally Posted by speedbucket View Post
perfect depends on how far away you are when you look at it:D
Originally Posted by Millermagic View Post
It's a 4.0 ... as long as there's something in the crank case that isn't coolant I'm sure it will still run forever.
Kettles is offline
post #3 of 14 Old 08-21-2009, 07:13 PM Thread Starter
Demonangel
yea it broke off body side
post #4 of 14 Old 08-21-2009, 07:51 PM
Holder350
1995 XJ Cherokee
If it has broken completely off welding is about your only option.
95' XJ Country - Stock Skids - D30/D35 Limited Slip - 3" Lift - 31x10.50R15 - 4.0 HO - AX15 - NP231
98' XJ Classic - D30/C8.25 - 4.5" RC Lift - 33x12.50R15 - 4.0 HO - AW4 - NP231
Originally Posted by Azzy View Post
You can tell the character of a person in how they treat someone who can do nothing for them.
Holder350 is offline
post #5 of 14 Old 08-21-2009, 07:53 PM
Kettles
Welding it back on is about the only option. Find somebody that can weld if you can't, or take it to a shop. Its a real bummer I am sure.
_=====o000o
Kettles is offline
post #6 of 14 Old 08-21-2009, 07:59 PM Thread Starter
Demonangel
yes it is when u have to get in thru the passenger side. hey anyone kno how to fix dash lights?
post #7 of 14 Old 08-21-2009, 08:20 PM
xjfever
xjfever's Avatar
1995 XJ Cherokee
How to door hinge repair
xjfever is offline
post #8 of 14 Old 08-21-2009, 08:24 PM Thread Starter
Demonangel
that helps but its the top hinge is broken of completely
post #9 of 14 Old 08-21-2009, 08:37 PM
xjfever
xjfever's Avatar
1995 XJ Cherokee
You will need to remove the front fender, grind the welds off the hinge and mounting surface, close the door and make sure it is aligned correctly, then carefully weld the hinge back in place. I welded mine all the way around. From the factory it is just welded partway across the top and bottom of the hinge, with some kind of sealer putty along the front side. Be sure to paint the area after welding to keep it from rusting.
xjfever is offline
post #10 of 14 Old 08-21-2009, 08:50 PM Thread Starter
Demonangel
that figures it would be somewhat complicated.
post #11 of 14 Old 08-21-2009, 08:54 PM
xjfever
xjfever's Avatar
1995 XJ Cherokee
You can do it without removing the fender, but it is much easier to get it done right if you remove it.
xjfever is offline
post #12 of 14 Old 08-21-2009, 09:07 PM Thread Starter
Demonangel
i only have a short period of garage time so i gotta leave the fender on.
post #13 of 14 Old 08-21-2009, 09:16 PM
1slosvt
It's not really that difficult. I did my gf's in a little more than two hours. That includes taking off the door AND fender and realigning everything. I should've just left the door on but I was hoping I could get in there with the welder- I couldn't.
-2012 JKUS
-2014 GC Laredo
-2k xj
1slosvt is offline
post #14 of 14 Old 08-21-2009, 09:19 PM Thread Starter
Demonangel
ok if i have to take the door off. is there an easy way to pop the bolts out?
Door Hinge Weld Broke Door Falling Off Repair DesertOne XJ Cherokee Technical Forum 9 10-23-2011 06:25 AM
Driver side door hinge terysmit XJ Cherokee Technical Forum 2 10-18-2009 07:32 AM
drivers door hinge messed up!! marinefreak200 XJ Cherokee Technical Forum 4 07-19-2009 06:01 PM
1992 laredo door hinge pin broke...how should I fix it a5tach XJ Cherokee Technical Forum 0 02-28-2009 11:40 AM
Driver door hinge broke! The_Other_One XJ Cherokee Technical Forum 14 04-03-2005 10:05 AM
