94 XJ - No start!!! - JeepForum.com
post #1 of 7 Old 05-17-2012, 10:32 AM Thread Starter
gwb16
1994 XJ Cherokee
94 XJ - No start!!!
OK - First, thanks in advance for any help that some of you more seasoned guru's may be able to send me!
Quick run down, 94 XJ, 4.0L....just replaced the battery today, it was due <5 years old. Previously replaced the alternator and starter, within the last couple of days. Hit the key and all I get is a big "click", sounds like the starter solenoid engaging, but she isn't turning over. Fresh charge on the battery. For grins and giggles, I attempted to jump start it...still only getting the "click"....I'm thinking I probably have a battery cable "issue". Anyone agree or disagree with me? Advice? Suggestions? I'm all ears at this point! She has 215K miles on it and still runs like a champ....when it was starting! LOL!
gwb16 is offline
post #2 of 7 Old 05-17-2012, 11:12 AM
Saudade
1988 XJ Cherokee
Check your grounds. Peel back some of the insulation from both battery cables and see if there's a lot of corrosion.
Saudade is offline
post #3 of 7 Old 05-17-2012, 11:34 AM
Armycherokee
1992 XJ Cherokee
X2 sounds like a bad connection
Armycherokee is offline
post #4 of 7 Old 05-17-2012, 01:46 PM Thread Starter
gwb16
1994 XJ Cherokee
Thanks! I'll give it a whirl when I get home this evening!
gwb16 is offline
post #5 of 7 Old 05-17-2012, 01:51 PM
MoparXJ
1993 XJ Cherokee
Try dropping into neutral and turning everything, simple way to eliminate one problem
MoparXJ is offline
post #6 of 7 Old 05-17-2012, 02:52 PM Thread Starter
gwb16
1994 XJ Cherokee
I just had my son go turn the headlights on - NOTHING! But, he said the seatbelt buzzer was going off when he turned the key on and the radio was playing...this thing is going to drive me crazy before it's over - LOL!
Starter relay gone bad?
gwb16 is offline
post #7 of 7 Old 05-18-2012, 05:14 AM Thread Starter
gwb16
1994 XJ Cherokee
It was the battery cables. I skinned back a short portion of insulation and it clearly had green oxidation, the negative cable didn't but I changed them all. She fired right up.
The alternator needed to be replaced (it bench tested bad), the starter probably didn't need to be, but it's new now, so I'm going to keep the old one as a spare.
Thanks again for the input!
gwb16 is offline
alternator , battery , starter , starting issue
1998 XJ Won't start on 1st try, fires right up on 2nd attempt / slow start spenceuiuc XJ Cherokee Technical Forum 18 08-06-2012 06:26 AM
No start......Replaced the Crank Sensor and still no start, Whats UP? batilzown XJ Cherokee Technical Forum 3 02-17-2010 12:50 PM
electric start prob. jeep wont start blackl4life XJ Cherokee Technical Forum 1 08-21-2009 08:56 AM
interesting hard start/no start/dead battery problem TXjeep97 XJ Cherokee Technical Forum 4 02-18-2008 08:18 PM
Eh.. start? no start? roll the dice? jiggle the cable? UnderDog! XJ Cherokee Technical Forum 6 05-25-2006 09:14 AM
