94 jeep cherokee xj - JeepForum.com
post #1 of 4 Old 10-01-2012, 05:36 PM Thread Starter
ErickHodges
94 jeep cherokee xj
Its acting like it's fuel starved. I thought it was the fuel injectors so I got seafoam and added to to my gas but its still having a hard time starting. It turns over so its not the starter. I can get it started by 'bump starting' it (holding the gas and clutch down to start it instead of the gas and break). I just don't know where to start
ErickHodges is offline
post #2 of 4 Old 10-01-2012, 05:59 PM
dmill89
1995 XJ Cherokee
When's the last time you changed the fuel filter?
dmill89 is offline
post #3 of 4 Old 10-01-2012, 07:14 PM
bassicsk8r
My first thought would be to look at vacuum connections. Is the a check engine light on? When the engines idling and you hit the brake, do the rpms change?
bassicsk8r is offline
post #4 of 4 Old 10-05-2012, 04:59 AM
94TwoDoor
1994 XJ Cherokee
Buy or borrow a fuel pressure tester and hook it up to the test point on the fuel rail. Should be like 40-45 PSI.
If fuel pressure is good and you still think it's fuel starved, then pull the rail and check the injectors. They could be gunked up and in need of a cleaning or replacement.
If fuel pressure is bad, then you've got the fuel pump, fuel pump relays/wiring, fuel filter, pressure regulator, or a leak somewhere as possible causes.
94TwoDoor is offline
engine , fuel , start problems
Can you swap jeep cherokee computer with grand cherokee jonnyboy99 XJ Cherokee Technical Forum 14 10-04-2014 11:42 AM
91 jeep cherokee versus 92 jeep cherokee rooneysin XJ Cherokee Technical Forum 6 08-10-2011 06:56 AM
Can i use a 96-98 jeep cherokee roof rack on my 97 jeep cherokee? 300zxnovaman XJ Cherokee Technical Forum 5 04-13-2011 09:17 PM
'88 Jeep Cherokee same transfer case as a '96 Grand Cherokee? sfsc XJ Cherokee Technical Forum 6 02-04-2011 02:08 AM
Will 1999 Jeep Cherokee SE seats fit my 91 Cherokee? Igofaster13 XJ Cherokee Technical Forum 11 01-16-2007 08:09 PM
