94 Cherokee Seat Belt Problem - JeepForum.com
post #1 of 22 Old 02-21-2011, 05:57 PM Thread Starter
alexk243
1994 XJ Cherokee
I have had my cherokee for a while and for some reason I just began to notice that the seat belts dont lock... for example when you hit the brakes or when you pull on the strap really hard the seat belt is loose... make me feel like they are pointless to wear. Anyways what do I need to do to make them safe again.
Thanks.
1994 Jeep Cherokee 4.0L
alexk243 is offline
post #2 of 22 Old 02-21-2011, 06:12 PM
daurwid
1991 XJ Cherokee
I grabbed replacements from the junkyard for my 91. Depending on what you want to do, I'd just replace them, it's usually the same cost/time effort involved.
daurwid is offline
post #3 of 22 Old 02-21-2011, 06:18 PM
bds5
Mine were doing that, then I realized the plastic around the red release button had slid down, so now when I latch I make sure the Plastic is pulled up and they work great.
bds5 is offline
post #4 of 22 Old 02-21-2011, 09:27 PM Thread Starter
alexk243
1994 XJ Cherokee
I am not sure if I described it right, the belt is buckling in, its just not locking tight under braking conditions like it should. What parts need to be replaced and how hard is it to do?
alexk243 is offline
post #5 of 22 Old 02-24-2011, 12:17 PM Thread Starter
alexk243
1994 XJ Cherokee
Anyone know what needs to be replaced on this?
alexk243 is offline
post #6 of 22 Old 02-24-2011, 01:10 PM
LandRover
LandRover's Avatar
So the buckle is staying buckled, but the belt continues to unwind out of the spool when you lean forward really hard, or apply the brakes hard?
RHD '98 XJ
RE 3.5", Bushwaker Flat Flares,
OR-Fab bumpers, PowerTrax locker,
Sliders, Goodyear Duratrac 33's
LandRover is offline
post #7 of 22 Old 02-24-2011, 01:10 PM
smitty81
seat belt units are non-serviceable.............
You will have to find replacements if you feel they are not working properly.
smitty81 is offline
post #8 of 22 Old 02-24-2011, 01:40 PM
scott_jeep
How are you testing them, with your hand or you actually stopped quick and they didn't lock up? I can't get mine to lock up by hand no matter how hard/quick I pull them. I always assumed it was normal as all 4 of them do it. I lock my Honda belts up just reaching for my wallet.
scott_jeep is offline
post #9 of 22 Old 02-24-2011, 01:59 PM Thread Starter
alexk243
1994 XJ Cherokee
Correct. The buckle is not the issue. Other side of the belt, just like you said it unwinds when hard braking or when you pull it.
alexk243 is offline
post #10 of 22 Old 02-24-2011, 02:01 PM Thread Starter
alexk243
1994 XJ Cherokee
Both. Pulling hard and by braking to a skid (non-abs jeep).
When I pulled the plastic cover off I noticed a wire harness not hooked up to anything right next to it and for the life of me I cannot imagine anything else that it could go to and if the belts are suppose to lock up on heavy braking then there has to be a wire going to the seat belt right?
Ill upload pics shortly.
alexk243 is offline
post #11 of 22 Old 02-24-2011, 02:02 PM Thread Starter
alexk243
1994 XJ Cherokee
Yea I am thinking junkyard... but I just want to make sure this is not normal first or something stupid like the belt not being connected or something.
alexk243 is offline
post #12 of 22 Old 02-24-2011, 02:12 PM
Kettles
Seat belts should be mechanical. I took apart one from a corrolla once and there was a ball bearing that acted as a weight, and if it wasnt pushing down on a lever it would lock the belt. So under heavy braking or in a rollover the ball moves and it locks. The yanking lockup was a centrifical force mechanism on the spool.
It shouldn't be electrical.
For what it is worth I can't get mine to lock up yanking on it, but it locks up on heavy braking.
_=====o000o
//__l_l_,\____\,____
l_--\_l__l_/--|lllll|
_.(o)_)__.(o)_)--o-)_)
"Dee", a Patriot Blue 2001 Cherokee Sport 4.0L High-Output
"Live Free Or Die; Death Is Not The Worst of Evils." -General John Stark
Originally Posted by speedbucket View Post
perfect depends on how far away you are when you look at it:D
Originally Posted by Millermagic View Post
It's a 4.0 ... as long as there's something in the crank case that isn't coolant I'm sure it will still run forever.
Kettles is offline
post #13 of 22 Old 02-24-2011, 03:04 PM Thread Starter
alexk243
1994 XJ Cherokee
So there should be something in the belt that makes it lock under braking? I will keep trying, but I cant seem to get it to lock. Good to know there is no electrical hookups on the belt. Could the ball bearing be stuck?
alexk243 is offline
post #14 of 22 Old 02-24-2011, 03:06 PM Thread Starter
alexk243
1994 XJ Cherokee
Just remember that I should probably note that a week or so before I noticed the belt not locking it locked up on my and would not get looser until I got in the jeep a while later and noticed that it was fine.
Dont know if that means anything but I thought I would mention it.
alexk243 is offline
post #15 of 22 Old 02-24-2011, 03:12 PM
smitty81
seat belts are mechanical.
There are two types of seat belts last i knew, One is called the pendulum style but I dont remember what the other is.
Here, read up.
http://auto.howstuffworks.com/car-dr...s/seatbelt.htm
smitty81 is offline
cherokee , seat belt
seat belt replacement problem NYREVIS24 XJ Cherokee Technical Forum 1 07-07-2010 03:14 PM
Seat belt help 1992 Cherokee Steady XJ Cherokee Technical Forum 2 04-22-2009 11:16 PM
Cold/Seat Belt Problem THISISWEIRD XJ Cherokee Technical Forum 2 12-10-2008 12:01 PM
89 cherokee seat belt question tech66 XJ Cherokee Technical Forum 2 12-08-2008 01:18 PM
Cherokee seat belt won't retract Springer74 XJ Cherokee Technical Forum 4 04-10-2008 02:20 PM
