94 Cherokee jerks in high gears and dies at idle - JeepForum.com
post #1 of 1 Old 07-04-2011, 04:28 PM Thread Starter
mtwilson87
1994 XJ Cherokee
My 94 XJ/Cherokee (4.0L, automatic transmission) will jerk pretty drastically when I am going down the interstate around 65-70 mph and try to accelerate slightly. I also does this when I am cruising around 45-50 mph and am slightly on the gas. If I accelerate hard through all the gears it will shift smoothly. Its only at low rpm's when I am slightly accelerating that it will jerk and make a clunking sound. I initially thought it may be a transmission problem but it shifts smoothly through low gears. I then replaced the TPS and nothing better. I just recently replaced the crankshaft position sensor also and that made it worse to the point where it wouldnt even idle correctly so I put the old one back on and now I am back at square one. The jeep also dies/shuts off randomly when its idling, or also when I am braking to stop at a stoplight. Any help or advice is much appreciated. Thanks in advance.
mtwilson87 is offline
clunking noise , dies , jerking , shifting issues , shifting problems
Renix 4.0 high idle, dies when warm Dead_End XJ Cherokee Technical Forum 11 09-06-2010 10:23 PM
Cherokee dies in idle after dead battery katdaddy1999 XJ Cherokee Technical Forum 5 08-27-2010 11:37 AM
90 cherokee low idle and dies danthejeepman90 XJ Cherokee Technical Forum 6 07-08-2010 11:03 AM
'99 Cherokee 4.0 dies randomly at idle, and now while running too jjhiker XJ Cherokee Technical Forum 9 08-15-2009 04:36 PM
Just dies and then starts to idle high pvasco XJ Cherokee Technical Forum 2 03-21-2007 02:00 PM
