'93 XJ - Oil Pressure Gauge Pegs - JeepForum.com
post #1 of 10 Old 01-03-2007, 08:57 PM Thread Starter
IdahoJeeper
This is a bit odd and kinda opposite the way oil pressure gauges and/or sending units goof up but mine reads off the scale while underway. After warmed up it will read about 20 psi at idle and will peg out as soon as you come off idle.
1.) Is this a common issue w/XJ's?
2.) My first thought is to replace the sending unit.
*No, I haven't connected a mechanical gauge to it.....yet.
Really I'm wondering if there are issues with the OEM gauges.
'95 ZJ Laredo, 4.0L, Auto, 225K, Forest Grn
'98 ZJ Laredo, 4.0L, Auto, 210K, White
IdahoJeeper is offline
post #2 of 10 Old 01-04-2007, 07:54 PM
jg08kk
2014 KL Cherokee
I believe I have a similar issue/question, My 99 Sport with 174,000 decided to idle at around 40psi of oil pressure and goes up to nearly 80 psi while highway cruising. Seems to be running fine, but, the oil pressure seems way high. It used to run in the 40-50 range. What is up with this??
JGXJ
jg08kk is offline
post #3 of 10 Old 01-05-2007, 05:34 PM
88XJSport
88XJSport's Avatar
1988 XJ Cherokee
If the oil pressure gauge is pegged, check the sending unit, near the oil filter, and make sure its connection is ok, then if it is ok, change the sending unit. They do go bad over the years.
88XJSport is offline
post #4 of 10 Old 01-05-2007, 06:34 PM
SerialKiller
2014 WK
Mine was pegged also so I replaced my sending unit and it's still pegged. I don't know what to do.
SerialKiller is offline
post #5 of 10 Old 01-05-2007, 07:51 PM
mortalenema
mortalenema's Avatar
My '93 XJ County had the same problem. I nearly messed my shorts the first time the gauge pegged. It took me about 5 minutes to figure out that every time I changed my oil filter and ended up hitting the sender that I was ruining the wires. I never did get around to fixing it when I sold it at 200k.
mortalenema is offline
post #6 of 10 Old 01-05-2007, 08:56 PM
BrunoS
failsafe feature. a dead gauge or bad ground always pegs the needle.
according to factory manual, disconnect wire, and gauge will peg. reconnect and it will go to zero with ignition on/no running condition; if gauge is ok.
they have been known to temporarily peg when starting a previously warmed up motor on a hot day, but as soon as idle is established, gauge should go to around 20 psi or so. rule of thumb: 10 psi per 1000 rpm.
Newly Painted! Emerald Green '96 XJ 4x4 4.0 HO 5-spd
3" Lift + 31" Tires / D35 TracLok / NP231
Drilled out Stock Airbox / Gauge Cluster Upgrade
Magnaflow Muffler / High-flo Cat / MSD Coil
BrunoS is offline
post #7 of 10 Old 01-13-2007, 09:36 PM Thread Starter
IdahoJeeper
Thanks for all the replies!!!
I replaced the sending unit ($23 @ O'Rielly's) and that fixed the problem. While I was at it, I tie-wrapped the wire (and wiring loom) to the mounting bracket for the oil dipstick to keep it out of the way of the filter.
post #8 of 10 Old 01-13-2007, 10:09 PM
snowblur17
snowblur17's Avatar
1993 XJ Cherokee
can a Bad sending unit cause any other problems?
'93 XJ. Crusty's 3"
bet you haven't heard of them 31" MTs
tcase skidage, and some other do-dads
snowblur17 is offline
post #9 of 10 Old 01-14-2007, 07:51 AM
tangofox007
They can cause the oil pressure gauge to be inaccurate. And they can leak oil. Short of falling out and becoming a road hazard, that's the extent of the problems that a "bad" oil pressue sender can cause.
tangofox007 is offline
post #10 of 10 Old 01-14-2007, 06:11 PM
severous01
severous01's Avatar
yeah, tell me now. mine blew off after an oil change. i look down and the guage reads full, i look up and see smoke coming up my windshield..i pull over immediately to find the sender dangling over the starter.
new unit and more oil and its fine....until last weekend when it died.
severous01 is offline
00 xj oil pressure gauge FG Jeep XJ Cherokee Technical Forum 1 11-13-2009 06:24 PM
Oil pressure gauge dert XJ Cherokee Technical Forum 10 12-30-2008 10:24 AM
oil presure gauge pegs rich08 XJ Cherokee Technical Forum 4 12-28-2007 01:19 PM
Oil Pressure Gauge gwayms XJ Cherokee Technical Forum 5 09-02-2007 09:30 PM
How-to oil pressure gauge? SerialKiller XJ Cherokee Technical Forum 4 12-16-2006 11:52 AM
