93 Jeep Cherokee No Crank - JeepForum.com
post #1 of 7 Old 10-28-2013, 11:44 AM Thread Starter
romomrk
1993 XJ Cherokee
She died electrically one day on me, First I replaced the battery which was due to be replaced, with the fresh battery she lasted about 6 hours and then left me stranded. After getting her back to my house apon crank I could only hear the fuel pump and the starter winding, so I directed my attention to the alternator. After replacing the alternator the engine would turn over almost completely without catching on. This period drove me mad replacing spark plugs fuel filter distributor rotor, but now nothing when I crank the only thing that chimes is the fuel pump I took the started off and had her tested which came back positive. Is it possible that I killed the ignition switch, and if so what would you direct as the culprit for the lack of a start.
romomrk is offline
post #2 of 7 Old 10-28-2013, 01:15 PM
M35A2
1995 XJ Cherokee
Possibly the neutral safety switch if you have an auto trans.
Volunteer, American Society of Military History. http://tankland.com/
Just got a 1989 YJ too!
M35A2 is offline
post #3 of 7 Old 10-28-2013, 01:24 PM Thread Starter
romomrk
1993 XJ Cherokee
If the NSS was bad wouldnt I be able to crank from Neutral position? Or is there some other way to trouble shoot that sensor?
romomrk is offline
post #4 of 7 Old 10-28-2013, 01:35 PM
M35A2
1995 XJ Cherokee
Depends on how gummed up the switch is. Somewhere here there is a how to on checking the NSS. Hold tite....
M35A2 is offline
post #5 of 7 Old 10-28-2013, 01:39 PM
M35A2
1995 XJ Cherokee
Try this...http://go.jeep-xj.info/HowtoNSSrebuild.htm
M35A2 is offline
post #6 of 7 Old 10-28-2013, 01:46 PM Thread Starter
romomrk
1993 XJ Cherokee
Im gonna go look into taking her off and cleaning her I appreciate the information and Ill keep the forum posted with my updates. Thank you.
romomrk is offline
post #7 of 7 Old 10-30-2013, 01:07 PM Thread Starter
romomrk
1993 XJ Cherokee
I took her off and cleaned out the gunk build up, bolted her back on connected everything back up and the jeep turned over ..just wouldn't catch on.
romomrk is offline
93 xj , alternator , electrical problem , starter , wont start
