93 Jeep Cherokee No Crank - JeepForum.com
post #1 of 2 Old 10-28-2013, 12:04 PM Thread Starter
romomrk
1993 XJ Cherokee
She died electrically one day on me, First I replaced the battery which was due to be replaced, with the fresh battery she lasted about 6 hours and then left me stranded. After getting her back to my house apon crank I could only hear the fuel pump and the starter winding, so I directed my attention to the alternator. After replacing the alternator the engine would turn over almost completely without catching on. This period drove me mad replacing spark plugs fuel filter distributor rotor, but now nothing when I crank the only thing that chimes is the fuel pump I took the started off and had her tested which came back positive. Is it possible that I killed the ignition switch, and if so what would you direct as the culprit for the lack of a start.
romomrk is offline
post #2 of 2 Old 10-28-2013, 12:20 PM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
Moved to XJ Forum.
The forum you posted in (JeepForum Announcements & Comments) is for quesitons about and help with the forum.
Welcome to the forum.
Wheelin98TJ is online now
alternator , electrical issue , jeep xj , starter , wont start
