'93 4.0 -- Correct way to test Pick-Up coil - JeepForum.com
post #1 of 6 Old 09-17-2009, 07:46 PM Thread Starter
Keiths93XJ
1993 XJ Cherokee
Does anybody know the correct way to test the pickup coil located inside the distributor under the rotor?
Keiths93XJ is offline
post #2 of 6 Old 09-17-2009, 07:57 PM
Ed Rico
1997 XJ Cherokee
From the '97 FSM, the sensor is physically different but operation is the same and diagnostic procedure should work for '93 4.0L:
CAMSHAFT POSITION SENSOR
The camshaft position sensor is located in the distributor
(Fig. 15) on all engines.
To perform a complete test of this sensor and its
circuitry, refer to the appropriate Powertrain Diagnostics
Procedures service manual. To test the sensor
only, refer to the following:
For this test, an analog (non-digital) voltmeter
is needed. Do not remove the distributor connector
from the distributor. Using small paper clips,
insert them into the backside of the distributor wire
harness connector to make contact with the terminals.
Be sure that the connector is not damaged
when inserting the paper clips. Attach voltmeter
leads to these paper clips.
(1) Connect the positive (+) voltmeter lead into the
sensor output wire. This is at done the distributor
wire harness connector. For wire identification, refer
to Group 8W, Wiring Diagrams.
(2) Connect the negative (-) voltmeter lead into the
ground wire. For wire identification, refer to Group
(3) Set the voltmeter to the 15 Volt DC scale.
(4) Remove distributor cap from distributor (two
screws). Rotate (crank) the engine until the distributor
rotor is approximately in the 11 oíclock position.
The movable pulse ring should now be within the
sensor pickup.
(5) Turn ignition key to ON position. Voltmeter
should read approximately 5.0 volts.
(6) If voltage is not present, check the voltmeter
leads for a good connection.
(7) If voltage is still not present, check for voltage
at the supply wire. For wire identification, refer to
(8) If 5 volts is not present at supply wire, check
for voltage at PCM 32-way connector (cavity A-17).
Refer to Group 8W, Wiring for location of connector/
terminal. Leave the PCM connector connected for
this test.
(9) If voltage is still not present, perform vehicle
test using the DRB scan tool.
(10) If voltage is present at cavity A-17, but not at
the supply wire:
(a) Check continuity between the supply wire.
This is checked between the distributor connector
and cavity A-17 at the PCM. If continuity is not
present, repair the harness as necessary.
(b) Check for continuity between the camshaft
position sensor output wire and cavity A-18 at the
PCM. If continuity is not present, repair the harness
as necessary.
(c) Check for continuity between the ground circuit
wire at the distributor connector and ground.
If continuity is not present, repair the harness as
necessary.
(11) While observing the voltmeter, crank the
engine with ignition switch. The voltmeter needle
should fluctuate between 0 and 5 volts while the
engine is cranking. This verifies that the camshaft
position sensor in the distributor is operating properly
and a sync pulse signal is being generated.
If sync pulse signal is not present, replacement of
the camshaft position sensor is necessary
Ed Rico is offline
post #3 of 6 Old 09-17-2009, 08:02 PM Thread Starter
Keiths93XJ
1993 XJ Cherokee
I dont have an analog voltmeter, but im sure a digital one would suffice. Can you by chance get me the wiring diagram from your source? This thing has three wires, and I wouldnt know which ones to probe.
Thanks a lot!
post #4 of 6 Old 09-17-2009, 08:20 PM
Ed Rico
1997 XJ Cherokee
Again from the '97 FSM:
5V supply - Orange
Camshaft Sensor Ground - Brown/Yellow
Camshaft Sensor Signal Output - Tan/Yellow
No idea if this is the same for '93, but I expect that it is.
-Ed Rico
Ed Rico is offline
post #5 of 6 Old 09-18-2009, 03:29 AM Thread Starter
Keiths93XJ
1993 XJ Cherokee
I believe You just gave me everything I needed.
You da man!
post #6 of 6 Old 09-23-2012, 09:30 PM
eddyagain
I also have same problem I changed CPS.
I checked resistance on coil , it checks out.
I checked distributer pickup coil, I have only power on the supply line, no power to the sensor outputs.
eddyagain is offline
No way to test or check coil rail, correct? BlkBird XJ Cherokee Technical Forum 8 03-08-2009 10:05 AM
Pic of pick up coil install? 96lt1z28 XJ Cherokee Technical Forum 4 10-23-2007 09:35 PM
[B]URGENT~!!!![/B] distributor magnetic pick up coil patchouli XJ Cherokee Technical Forum 9 08-08-2007 09:59 PM
Correct Coil-Spring Spacer Install. XJ4oh XJ Cherokee Technical Forum 15 10-20-2005 11:48 PM
Help me pick the correct High-Flow Cat from this Ebay Seller NJXJ2315 XJ Cherokee Technical Forum 8 05-03-2004 12:31 PM
