92 XJ Sport - intermittent grinding noise + low oil pressure + oil drip near TC - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > XJ Cherokee Technical Forum > 92 XJ Sport - intermittent grinding noise + low oil pressure + oil drip near TC
FREE, FREE, FREE EVENT!! Save big on Lockers now till ApriJKS Grand Cherokee WJ, Adjustable Front Trackbar 1"-6Teraflex JK HD Hinged Carrier & Adjustable Spare Tire
Unread 10-20-2013, 12:23 PM   #1
wiwa
I have a 92 XJ sport i just recently got on the road after replacing the fuel pump and water pump.
It was always eating oil and had a low oil pressure 10-20 psi on the gage.
I took a 500 mile trip to Austin, and at some point i started to hear a faint grinding noise from below the center console / shifter. Sometimes it's louder, sometimes it's barely noticeable.
The most noticeable is when i'm coasting at a low speed, < 5mph, and continues even when it's in neutral. Sometimes it will come up at higher speeds while accelerating.
I was wondering if anyone had experienced this before, as to where the noise might be. Could it be the same bearing / seal causing the oil drip near the TC? or might it be some damage to the inside of the TC?
Thanks for any input!
wiwa is offline   Reply With Quote Quick reply to this message
Unread 10-20-2013, 02:48 PM   #2
Bills03tj
1992 XJ Cherokee
Check your u joints. Also check the fluid level in the transfer case.
Bills03tj is offline   Reply With Quote Quick reply to this message
transfer case , transmission
