92 XJ Slow Crank - JeepForum.com
post #1 of 10 Old 08-07-2005, 04:27 PM Thread Starter
ExplorerDMB
92 XJ Slow Crank
I've got a 1992 Cherokee that has a slow crank. It doesn't seem to be a fuel issue, because if I turn the key on to prime the system, it still takes the same amount of time to actually start. I recently did a tune up which included distributor cap and rotor. Any thoughts?
-Drew
ExplorerDMB is offline
post #2 of 10 Old 08-07-2005, 04:43 PM
SuperStreetJeep
SuperStreetJeep's Avatar
1993 XJ Cherokee
mine does that too, it acts like it doesnt wanna start but it always does...Always!
I was wondering how much you paid for ur cap and rotor i only did plugs and wires today was curious i might go back and do cap and rotor tomorrow
Think Your Jeep Is Fast??? Click Here!!!
SuperStreetJeep is offline
post #3 of 10 Old 08-07-2005, 07:11 PM
skyjacked94xj
skyjacked94xj's Avatar
My cranked slow before, it didn't seem like a dead battery.. But then i out a new battery in and it solved all my slow cranking problems.. I'd give it a try if your battery is old.
DAILY DRIVER
1996 Cherokee Classic
4.0HO 5-SPEED! | 16x8 Rucicon Moabs | lowered 1" | clear corners | silverstars | custom waggy taillights | custom intake | Aem TB spacer | Dynomax cat-back | Bored TB | FirePower Ignition Kit
CLASSIC TOY
1968 Chevy C-10 short bed
Chevy 350 crate motor | 4-speed | fully restored | Lowered | 20" Centerline Daggers.. wayyy too much to list
Project
1988 Pontiac Trans Am GTA
350 TPI | WS6 | 48k original miles | Flame Red Metallic
SOLD: 94 cherokee | Lifted | Locked
SOLD: 97 TJ | 33's | 4.56's | :(
Searching for an Ls-1 Rx-7 project....
skyjacked94xj is offline
post #4 of 10 Old 08-07-2005, 07:49 PM Thread Starter
ExplorerDMB
I replaced the battery awhile back. My charging system runs beautifully, around 13.8v when running.
SuperStreetJeep - I can't remember the exact cost of the cap and rotor, but I think it was like 25 bucks for the set from NAPA.
-Drew
- '92 Laredo 4x4
- '00 XLT 4x4 7" Lift, 4.56s, LSD, 33's
post #5 of 10 Old 08-10-2005, 08:48 PM Thread Starter
ExplorerDMB
to the top = bump
- '92 Laredo 4x4
post #6 of 10 Old 08-10-2005, 08:59 PM
Jeepin Cam
cap and rotor are cheap like 10 for the cap and 5 for the rotor. now that you said something about the batt I remeber that did help my dads jeep it was cranking slow and a couple weeks later the batt died and needed to be replaced and then it started fine after that. for some reason batts died alot here in FL cause like once a year we have to go get a new one but it is still under warrany so we just have to pay teh disposal fee like 1.50$
92 Larado, 4x4, 4.0 liter, 140,000 miles, 3 Inch Rocky Road BB, 31 ATs
95 Country, 4x4, 257,000 miles runs like a champ!!, 4.0 liter, Stocker can't convince dad it needs a lift!!
Jeepin Cam is offline
post #7 of 10 Old 08-10-2005, 09:41 PM
balloo93
Little Red Menace
balloo93's Avatar
1993 XJ Cherokee
When I had a accel super coil on mine it started much faster than with stock. Of course the accel coil died about 2k later and I went back to the stock one.
One of these days I will get a MSD unit, but for now I just put of with a slightly longer start time. AutoZone sells the MSD unit for around $50.
93 Sport
Beer is proof that God loves us and wants us to be happy............Ben Franklin
Specs in Profile.
balloo93 is offline
post #8 of 10 Old 08-13-2005, 10:20 PM
XJohnnyC
XJohnnyC's Avatar
How are the battery cables? Are they corroded at the terminals?
XJohnnyC is offline
post #9 of 10 Old 08-13-2005, 10:37 PM
Kuasimodem
Kuasimodem's Avatar
The number one enemy of your battery is heat. Hot summer temps and the added engine heat will cook and kill a battery very quickly.
White Jeep Club Member #1992
Original Rust Jeep Club Member #5!
Old Guy Jeep Club Member #1992
"The most terrifying words in the English language are: I'm from the government and I'm here to help." - Ronald Reagan
Kuasimodem is offline
post #10 of 10 Old 08-14-2005, 01:32 PM Thread Starter
ExplorerDMB
No not at all. I would of noticed that a long time ago if that was the problem. I believe even when we replaced the battery it did not help out the "cranking" issue.
-Drew
- '92 Laredo 4x4
1990 4.0 slow to crank tagalong XJ Cherokee Technical Forum 3 07-15-2008 02:13 PM
crank crank crank no start lostxj XJ Cherokee Technical Forum 8 04-05-2008 11:36 AM
Slow start/crank speed. MageXX9 XJ Cherokee Technical Forum 3 10-16-2006 04:32 AM
crank crank crank then start GDSQDCR MJ Comanche Technical Forum 2 08-29-2005 12:09 PM
Starter solenoid and slow crank? adreed24 XJ Cherokee Technical Forum 1 04-26-2005 07:42 AM
