92' Jeep Cherokee stuck in 4x4 part time? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > XJ Cherokee Technical Forum > 92' Jeep Cherokee stuck in 4x4 part time?
ROCKRIDGE4WD Introduces a NEW Jeep Wrangler JK *led* tail ANOTHER Rockridge4wd Creation!! Spare Tire Carrier Delete Building a Bumper?
Unread 07-22-2014, 09:41 AM   #1
TheNightingale
1992 XJ Cherokee
Hello guys!
About a month ago I bought a 92 Cherokee I don't know much about Jeeps since it's my first one everything was going great, until today.
I was going on a muddy gravel road so I engaged 4x4 part time, worked good then when the gravel finished I switched back to 2wd and worked I drove like for 600 mts, and encountered more dirt and rocks and a slope. Switched back again to 4x4 part time when up the slope and arrived to my destination.
After I parked the Jeep I tried to switch it back to 2wd and the lever went to the position but the light of 4x4 part time stayed on. I pulled the lever all the way back to neutral and it worked because the transmission was in neutral switched to drive and I tapped the gas pedal and the truck didn't move, I switched it to 2wd and it seemed to work but the 4x4 part time light keeps on.
How can I know that is on 2wd I don't want to damage the transfer case also do you think it's the sensor malfunctioning as it's and old Cherokee with 250 k miles on it
Thanks a lot
TheNightingale is offline   Reply With Quote
Unread 07-22-2014, 11:39 AM   #2
bigislandhikers
1989 XJ Cherokee
Give it gas on dirt or gravel and see if the back tires spin. Sometimes I have to put it in reverse and backup a few feet to get it back into 2wd.
bigislandhikers is offline   Reply With Quote
Unread 07-22-2014, 11:47 AM   #3
Paradise XJ
1990 XJ Cherokee
The truck won't move if the t-case is in Neutral...even if the tranny is in gear.
Put it back in 2H and drive for a bit. Uusally only 20 ft or so and the light should go off.
1990 XJ Laredo - White & Chrome
1988 MJ Pioneer - Metallic Green and Black
Paradise XJ is offline   Reply With Quote
Unread 07-22-2014, 06:23 PM   #4
TheNightingale
1992 XJ Cherokee
Thanks a lot, it worked. I put the tranny in Reverse and backed up and went back and forth and on the 4th try it worked.
Unread 07-23-2014, 06:16 AM   #5
bigislandhikers
1989 XJ Cherokee
Glad it worked. I used my 4wd a lot last winter and it seems to get stuck less often.
