92 idle voltage issue - regulator? - JeepForum.com
post #1 of 7 Old 11-10-2012, 03:58 PM Thread Starter
Tomguy
2014 WK
I have an odd idle voltage issue with my 1992 XJ. I don't think it's the alternator, I'll go into more detail as to why:
When I'm idling (headlights on or off, fan on or off - doesn't seem to matter, just affects how low it goes) my voltmeter drops like a rock. I'm steadily at 14v at startup, and if I drive it's fine, but when I'll come to a stop, my volts drop to around 12 (sometimes 10-11 with everything on). If I give it a little bit of gas and let it drop back to idle, the volts are fine at idle again, even if my headlights, blower etc are all on. I think it may be the voltage regulator or something else in the charging system - the diode or whatever that attaches to the alternator maybe? If so how do I replace it?
It was doing this before I replaced the alternator (which was buzzing/whining) and seems to be doing it just as much now, so I don't think it's the alt (especially since giving a touch of gas to get the volts up again, then dropping back to idle, will let it run just fine). My lights dim visibly and it runs a little rough when the voltage drops way down, not surprisingly.
Does anyone know where the voltage regulator is, if it's not that piece attached to the alt wire? And what is that piece, and how does one replace it?
Thanks!!
Hemi, Towing & Lux
198k
Previous: 1972 Benz 280SE 4.5, 1992 XJ Cherokee Laredo, 2006 Charger R/T
Tomguy is offline
post #2 of 7 Old 11-12-2012, 04:33 PM Thread Starter
Tomguy
2014 WK
Monday bump. Did a search but maybe I'm not searching right, or it's too broad of a topic?
Hemi, Towing & Lux
198k
Tomguy is offline
post #3 of 7 Old 11-12-2012, 08:54 PM
duzrock
The voltage regulator is part of the ECU , the engines brain. I would first check all battery and ground connections, including all connections at the fuse block. Check the plug that goes into the ECU.
duzrock is offline
post #4 of 7 Old 11-12-2012, 09:40 PM Thread Starter
Tomguy
2014 WK
I replaced the ECU (my old one died), it did this on the old one as well. The battery connections are all good. I even replaced the entire (+) cable because of fraying @ the connector.
Thanks for the advice and help, I am guessing that not many people have or had this issue?
Hemi, Towing & Lux
198k
Tomguy is offline
post #5 of 7 Old 11-15-2012, 06:37 AM Thread Starter
Tomguy
2014 WK
Bump for a hopeful solution!
Hemi, Towing & Lux
198k
Tomguy is offline
post #6 of 7 Old 11-22-2012, 02:17 PM Thread Starter
Tomguy
2014 WK
Happy Thanksgiving bump!
Hemi, Towing & Lux
198k
Tomguy is offline
post #7 of 7 Old 11-22-2012, 10:58 PM
Paradise XJ
1988 MJ Comanche
Did you check your block to firewall ground? How about the grounds at the oil dipstick bolt. It also wouldn't hurt to place an additional ground off the battery (-) to fender. Shining up and refreshing my grounds (ala Cruiser54's write-up) fixed my voltage problems. My gauge is now straight up 14 unlesss I'm running everything at once, even then it just drops a blip.
1990 XJ Laredo - White & Chrome
1988 MJ Pioneer - Metallic Green and Black
Paradise XJ is offline
