'92 Cherokee won't go over 10mph - Page 2 - JeepForum.com
post #16 of 41 Old 09-27-2009, 11:50 AM Thread Starter
koolaid5
Stuck In The Garage!
koolaid5's Avatar
1992 XJ Cherokee
I'm going to pick it up in the morning. I've decided. It's even running fine right now, so if I can find someone to drive me up there I'll be able to get it home... OR... I wonder if I can just throw it on my insurance, include roadsixe assistance and get it towed home
Then I'm looking at another one that just appears to need the CPS replaced. I have him down to $900 from $1100 so far. That's a very clean looking '92 as well with only 153,000 on it.
koolaid5 is offline
post #17 of 41 Old 09-27-2009, 11:52 AM
ehall
1991 XJ Cherokee
blocked airflow somewhere... the computer fires the injectors according to the amount of air in the intake, so bad airflow means limited fuel and inability to throttle up the engine
ehall is offline
post #18 of 41 Old 09-27-2009, 06:47 PM
Codetalker
1990 XJ Cherokee
yeah there is a hissing noise coming from the intake and all the vacuum hoses are fine.
Codetalker is offline
post #19 of 41 Old 09-27-2009, 07:35 PM Thread Starter
koolaid5
koolaid5's Avatar
1992 XJ Cherokee
Ok, thanks for the info....
I wanted to go and pick it up tomorrow, but I don't have a ride up there to Clayton, NC, so that I could drive it home. I'm still going to go up and see it and possibly buy it and get the title in my name.....just no way to get it home. If I can't get a ride up there I'll see if I can borrow a trailer from a guy at work. It's sad... my really only friend down here is heading to Comumbia tommorrow on a deployment.... Now I have not help doing anything Too many deployments and too much moving around isn't a great help in making buddies.
koolaid5 is offline
post #20 of 41 Old 09-27-2009, 07:48 PM
xjfever
xjfever's Avatar
1995 XJ Cherokee
The problem could be the cat has came apart on the inside and the junk blowing around in there is clogging it sometimes. You can hit the cat a few times and see if you hear loose junk in there.
xjfever is offline
post #21 of 41 Old 09-28-2009, 11:03 AM
Codetalker
1990 XJ Cherokee
but i disconnected the cat from the exhaust line and it had the same problem. does anyone know where i could get a cpu connector so i could hook it up to it?
post #22 of 41 Old 09-28-2009, 12:13 PM Thread Starter
koolaid5
koolaid5's Avatar
1992 XJ Cherokee
going to go pick up that Jeep here in about half an hour. Wish me luck on the hour long drive home with it
koolaid5 is offline
post #23 of 41 Old 09-28-2009, 12:15 PM
Kettles
luck! .
_=====o000o
//__l_l_,\____\,____
l_--\_l__l_/--|lllll|
_.(o)_)__.(o)_)--o-)_)
"Dee", a Patriot Blue 2001 Cherokee Sport 4.0L High-Output
"Live Free Or Die; Death Is Not The Worst of Evils." -General John Stark
Originally Posted by speedbucket View Post
perfect depends on how far away you are when you look at it:D
Originally Posted by Millermagic View Post
It's a 4.0 ... as long as there's something in the crank case that isn't coolant I'm sure it will still run forever.
Kettles is offline
post #24 of 41 Old 09-28-2009, 07:32 PM Thread Starter
koolaid5
koolaid5's Avatar
1992 XJ Cherokee
WOW!!! THAT was an experience
My first thought was ..... eh..... $300 no matter what condition it's in I'll pick it up and if it's in too bad of condition I can at least sell a few things to break even or even go ahead a few $$'s
When I got to this ladies TRAILER she had it running hhhhmmm... wonder why? Maybe because the starter is SHOT and you have to attempt to start the f'er 25 times before it finally catches and fires up? Yeah....probably. So, I knew it was in bad shape, but check out this list...
Driver's side door top hinge needs rewelded. It's still attached to the door and needs tacked back on to the body, so anytime you open the door you have to hold it up and then get the f'er to close
It has a sun roof but it leaks It leaked so long that it jacked up the headliner, so someone just yanked it all down... for the most part anyway...still has some crap hanging down
The passanger side mirror got knocked off. That's an easy fix though. It's just the rear clip that broke. I'm just going to jb weld that bastard in place for now.
She SAYS that the heat and A/C works, but the blower doesn't turn on.
No rearview mirror
a bunch of other little things inside.... and it SMELLS. If I get this running right the next thing I'm doing is stripping the seats out and attempting to salvage the carpet, but possibly just ripping it all out and spraying U-POL Raptor bedliner like I just did with my TJ. I actually considered just yanking the front doors off since they're jacked up anyway and going that route
ok....now to the engine/exhaust. She said that the pipe connecting to the CAT was disconnected... YEAH, because the F'N muffler is missing
While I drove it around town to get the title notarized it had pretty good pick up and although stupid loud it drove alright. Shocks could use replaced in the next year, tires as well, but overall not too bad for $300.
THEN.....THEN.... I get it on the highway. The first 15 minutes it acted fine, but then I just started losing pwr. It just had no "oomph" I could go about 45mph and that was it. At first I was trying to force it to shift and go faster, but it didn't seem to matter what gear I was in. It still wouldn't get up and go. So, to avoid pushing it too hard and causing it more problems I laid off it a bit. Sat in the right lane at 40-45 with my flashers on. What could be causing this... here are my thoughts
F'N exhaust
TPS
Clogged/Crappy fuel filter
Oh, and checked the air filter and it looks pretty new
IDEAS...THOUGHTS.... COMMENTS....LAUGHTER Let me have it
koolaid5 is offline
post #25 of 41 Old 09-28-2009, 07:48 PM
Kettles
Stop complaining about a $300 xj and send it my way...
Power loss could easily be the cat being clogged. If not than I would guess something with the fuel system.
Door problem is terribly common with the pre 97's because the limiting strap on the door is too long, so swinging it all the way open yanks the hinges, eventually ripping them off. For the blower check the fuses and such first.
For the interior strip all the carpet and headliner out, and coat it with wahtever you want. You can even put sound deadening material down and the bedline it. Then take the seats out and wash them if they smell, you can rent a carpet cleaner machine or something if you want.
Get a cheap muffler and put it on.
and If it were mine I would chop the top off and have some fun with it.
_=====o000o
Kettles is offline
post #26 of 41 Old 09-28-2009, 08:47 PM Thread Starter
koolaid5
koolaid5's Avatar
1992 XJ Cherokee
Funny you should mention about the top. I had that thought when I was chugging down the highway today. that would be sweet. I was thinking...lose the doors, rip out the carpet, spray in bedliner, and chop the top off, that would kick ***. )
I'm not complaining....just venting a bit. I know I have a bunch of work ahead of me. The top of the list is the power issue, the doors to actually be able to open and close (or taken off all together), and exhaust taken care of.
I have a question about the exhaust. Where can I pick up a cheapo to get me by? Should I just go ahead and replace the CAT as well or is there a way to check it? Can I do the exhaust myself or do I need to take it somewhere? I put an exhaust on my motorcycle, but the scale is a bit smaller there I can't weld...YET... but I'd like to learn. If there is no welding involved then I guess I can handle it...just need to know where to go to get one....used from junk yard, or cheapo off of ebay, or local muffler shop or what ?????
Thanks for the help
koolaid5 is offline
post #27 of 41 Old 09-28-2009, 08:50 PM
Kettles
I think a local muffler shop would do it pretty cheap. Its just some bent tube, and the muffler. Multiple online companies sell cat back systems too.
As for the cat, I hear you can hit or shake it and listen if anything moves. It the insides move then it needs to be replaced.
_=====o000o
Kettles is offline
post #28 of 41 Old 09-29-2009, 06:28 AM Thread Starter
koolaid5
koolaid5's Avatar
1992 XJ Cherokee
Look for my new thread on this "build", if that's what you want to call it . It will be called "BEATER BUILD" I'll come back here and post a link. I think it will get more traffic than this one though.
*edit*
http://www.jeepforum.com/forum/f11/3...-build-867664/
koolaid5 is offline
post #29 of 41 Old 09-29-2009, 01:54 PM
Codetalker
1990 XJ Cherokee
i also bought a xj for cheap but the lady i bought it from had it in pretty good condition just needed to be vacuumed out and new fuel pump an it was good as new. but now its busted. i tried the cat and no hope, replaced the fuel filter, fuel pump (again), fuel rail, fuel lines, and put in a new o2 sensor, oil pump, but still nothin, but before this happend i noticed that when i got to like 45 mphs it would shake and then when i would get to like 50 mphs it would stop shakin, but now its just totally outta power, anyone on here have any ideas on wat it might be? other than, cat, muffler, fuel system, or o2 sensor?
post #30 of 41 Old 09-29-2009, 02:54 PM Thread Starter
koolaid5
koolaid5's Avatar
1992 XJ Cherokee
Did you check the Throttle position sensor (TPS)???
Is it COMPLETELY dead or just won't go over a certain mph?
Good Luck
koolaid5 is offline
'96 Grand Cherokee Seats and Center Console in a '96 Cherokee? 96cherokeesport XJ Cherokee Technical Forum 16 09-25-2010 05:35 AM
Hey Cherokee owners...Will stock 2005 Wrangler Wheels fit a 95 Cherokee? RedArrow10 XJ Cherokee Technical Forum 3 07-23-2009 11:41 AM
Will a 1989 Cherokee block work on a 1993 Cherokee? twmart XJ Cherokee Technical Forum 3 08-23-2008 06:18 PM
5spd cherokee engine fit automatic(duh) grand cherokee? jumpn4jesus XJ Cherokee Technical Forum 5 07-02-2007 10:34 AM
Just bought a Grand Cherokee so finally lifting my old Cherokee... wino_ii XJ Cherokee Technical Forum 4 04-22-2005 05:07 PM
