92 4.0 mechanical temperature gauge... - JeepForum.com
post #1 of 4 Old 04-28-2014, 12:54 PM Thread Starter
Gigemags05
1980 CJ7
Does anyone know of a gauge that has a fitting to fit the factory temp sender threads on the rear of the head on a 92 4.0?
I have gone through 2 aftermarket crappy temp gauges and would like to install a mechanical gauge. But all of the mechanical gauges I find come with 1/2 inch NPT thread for the probe which is too big.
I don't want to tap into the head to enlarge the threads. Anyone else have an option for running a mechanical temp gauge?
Gigemags05 is offline
post #2 of 4 Old 04-28-2014, 07:15 PM Thread Starter
Gigemags05
1980 CJ7
Anyone?
Is there another place that I could find this info?
post #3 of 4 Old 04-28-2014, 08:03 PM
dmill89
1995 XJ Cherokee
I don't think I've ever seen a mechanical temp gauge with a probe small enough to fit the stock location. The stock sender is electrical and mechanical probes are generally larger than electrical senders since they are filled with fluid (which expands with temp and actuates the gauge).
A good quality (Autometer, Stewart-Warner Deluxe/Heavy-Duty, etc.) electrical gauge should work well and fit the stock sender location. Cheap gauges are usually cheap for a reason.
dmill89 is offline
post #4 of 4 Old 04-29-2014, 09:04 AM Thread Starter
Gigemags05
1980 CJ7
thank you for the response.
I will look into getting a better electrical gauge.
