92 4.0 Jeep revving up after stopping - have to keep foot on brake - JeepForum.com
post #1 of 6 Old 07-02-2008, 11:28 PM Thread Starter
variable
variable's Avatar
So this friend of mine has an automatic 92 cherokee 4wd with the 4.0 HO in it and for some reason when she comes to a stop light, 15-20 seconds later the engine will start revving up and she'll have to hold the brake down really hard to keep it from moving. It also I guess does it when she's in neutral and will rev up to like 2000 rpm and just stay there. I've poked around and only found a few things that hint maybe at the master cylinder, but I'm skeptical. Anyone see this before?
93 ZJ V8 5.2 - K&N FIPK, leaky exhaust
variable is offline
post #2 of 6 Old 07-02-2008, 11:58 PM
jc052685
1990 XJ Cherokee
idle air control valve?!?!
jc052685 is offline
post #3 of 6 Old 07-03-2008, 12:12 AM
balloo93
Little Red Menace
balloo93's Avatar
1993 XJ Cherokee
That would be my guess as well.
93 Sport
Beer is proof that God loves us and wants us to be happy............Ben Franklin
Specs in Profile.
balloo93 is offline
post #4 of 6 Old 07-03-2008, 12:21 AM
bushytails
Or toasted brake booster... 2000 rpm is low enough it also could be a normal vaccum leak.
--Bushytails
bushytails is offline
post #5 of 6 Old 07-03-2008, 12:34 AM
xjpro
If your idle control valve is serviceable, just take it out and give it a good clean with carburetor cleaner.
Hope this helps!
xjpro
01 xj limited
ZJ rear disc brakes with working parking brake
Electric fan conversion with spal fan controller
xjpro is offline
post #6 of 6 Old 07-03-2008, 01:09 AM Thread Starter
variable
variable's Avatar
I couldn't find any vacuum leaks, and it its very inconsistent as to when it happens, i.e. not very often so I haven't actually been able to reproduce it myself. But I'll look into the idle control valve.
Thanks guys!
variable is offline
My Jeep won't run without foot on gas pedal. DenverChreokee XJ Cherokee Technical Forum 10 07-19-2015 02:52 PM
New Jeep owner - stopping in to say hello ChefEvans XJ/MJ Cherokee Non-Technical Forum 5 08-24-2008 01:52 PM
Jeep 0 - Six Foot Hwy Median Cement Wall 1 BatmanX XJ Cherokee Technical Forum 16 12-20-2007 05:46 PM
Rough Weird Idle with Foot on BRAKE dlwt2003 XJ Cherokee Technical Forum 11 09-19-2007 04:43 PM
foot brake swapout ?s Ed in North Ga MJ Comanche Technical Forum 4 05-30-2005 06:39 PM
