'91 XJ Rear Bumper Build - Doing it strong - JeepForum.com
post #1 of 6 Old 07-28-2012, 11:33 PM Thread Starter
Diamond-x
1991 XJ Cherokee
I need a new rear bumper. It's either that or long-arms. I'm not really prepaired for that. So a bumper it is. I always overbuild everything,
knowing this I decided on 2x4 stock instead of 2x6. I got 10 feet of 3/16" at the local steel yard.
I also picked up some scrap 2" strap x 3/16" and a hitch receiver.
I was motivated by a couple of builds worth mentioning:
Paraleyes rear bumper build is the best I've seen. http://www.jeepforum.com/forum/f11/c...t-way-1007865/
Husslers Doing it Perfect is an exercise in free thinking. http://www.jeepforum.com/forum/f37/d...rrier-1331910/
Both contain a solid build and a classic design.
Hopefully, I can make one that looks respectable.
I made inserts
added ears
Gave it some shape
Centered and tacked it
and welded it up
I also trimmed the ends, added runners to protect the fenders, cut the cavity for the hitch, added the hitch and tail-light risers, finish welded.
Some time later
Cleaned up
I'm planning on adding chain hoops and strengthing the receiver. I'll add some random gussets,
weld in some low spots and final grind, then some bondo to smooth it out, prime and paint.
More pics to come
Diamond-x is offline
post #2 of 6 Old 07-29-2012, 02:36 AM
jakeleverett
Looking good! Great start! Im excited to see it all painted up! This is similar to what I would like to do when I get down to building mine!
jakeleverett is offline
post #3 of 6 Old 07-29-2012, 07:29 AM
cbenez1
Nice job !
A nation that forgets it's defenders will itself be forgotten
01 Up Country 6.5 long arm
cbenez1 is offline
post #4 of 6 Old 07-29-2012, 09:21 PM Thread Starter
Diamond-x
1991 XJ Cherokee
Some progress
Added gussets to the hitch
Chain hoops
Installed
Finished
Removing the old hitch significantly improved the departure angle. I zip tied the trailer wiring for now, I'll fab a bracket for it.
I also plan on a swing out. I have a swing down hitch mount that is back on, it's functional but hides the bumper.
That's it for now
post #5 of 6 Old 07-29-2012, 10:15 PM
wgirvine
1992 XJ Cherokee
Don't mean to insult you, but your welds need to be better. Grinding and Bondo is no substitute for a good weld. Bad welds break, and I know you don't want that. Practice, practice, practice... find a guy who's really good and ask for advice. Search YouTube for welding videos, but be warned... half of those are flat-out wrong. Don't get frustrated; making really good welds is hard. Practice some more...
The road goes on forever, the party never ends....
wgirvine is offline
post #6 of 6 Old 07-29-2012, 11:09 PM Thread Starter
Diamond-x
1991 XJ Cherokee
I never did get around to putting any bondo on it, just filled the low spots with weld and hit it with the grinder and flapper.
That hitch isn't going anywhere. Welds may not be pretty but the heat signature indicates good penetration. There is also some slop from the flux.
buying rear bumper soon, what is strong enough for recovery? DoctorTim XJ Cherokee Technical Forum 6 11-08-2011 01:11 PM
rear bumper not strong enough solidsnake1761 XJ Cherokee Technical Forum 5 10-01-2010 02:32 PM
XJ rear bumper build maximum729 XJ Cherokee Technical Forum 21 02-02-2010 04:47 PM
Custom winch bumper and rear bumper build (almost finished) Tkjeeper53 XJ Cherokee Technical Forum 5 11-06-2009 07:30 AM
XJ Rear bumper build #1 88WoOdY XJ/MJ Cherokee Non-Technical Forum 10 05-13-2009 12:07 AM
