91 Radiator in a 89 Cherokee will it fit? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > 91 Radiator in a 89 Cherokee will it fit?
Rough Country Deals at JeepHut.comIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineJeep JK Wrangler 3" Suspension Lift Kits $439.99 deli
Unread 08-04-2010, 09:03 AM   #1
My1989Jeep
1989 XJ Cherokee
I have a chance of getting a radiator for a 91 at a very good price, but will it fit my 89 XJ? Will I have to drill new holes? Has anybody done this before and is it worth it?
1st 1989 Jeep Cherokee Laredo. 4 Door. Automatic. 4.0L Straight Six.
My1989Jeep is offline   Reply With Quote
Unread 08-04-2010, 10:08 AM   #2
BriansCJ
1994 XJ Cherokee
Nope. The 89 is a closed system where the 91 is an open system.
You would have to change all of your hoses, HCV, get an overflow bottle, and get a rad cap.
Edit: I wil check if my rad has trans lines. If it does, You can have it if you pay for shipping. Anything from 87-90 will (should with trans cooler lines) fit.
I will be doing a write-up on it, when I am done the interior/bedline write up.
5 Speed XJ Build - Daily Driver & Weekend Wheeler
1978 CJ5 Resto, w/ heavy mods - Slow
BriansCJ is offline   Reply With Quote
Unread 08-04-2010, 11:19 AM   #3
twmart
I have seen a few write ups on this and have seen 1 in person. I am looking into starting to collect the pieces needed to do this on my 89 and 90.
- Radiator
- Overflow bottle
- Heater by-pass
- Heater hoses
The one I saw he had to cut the radiator support to fit the radiator fill tube.
Here is one of the write ups..
JeepsUnlimited.com
1989 Cherokee
1990 Cherokee
1999 Grand Cherokee
2001 Cherokee
twmart is offline   Reply With Quote
Unread 08-04-2010, 10:29 PM   #4
My1989Jeep
1989 XJ Cherokee
The upgrade would be sweet. Gonna go to the junk yards to see how all the parts go on a 91 verses an 89.
Unread 08-09-2010, 11:02 PM   #5
My1989Jeep
1989 XJ Cherokee
BriansCJ I sent you a PM
Unread 08-09-2010, 11:04 PM   #6
Willy36
1990 XJ Cherokee
Like said, it will work, just with modification. I recommend it. The closed system is good when it works, but it will give you problems eventually....They always do.
Willy36 is offline   Reply With Quote
Unread 08-10-2010, 12:08 PM   #7
Mkonyn
1997 XJ Cherokee
There's a writeup here
Mkonyn is offline   Reply With Quote
