91 anti lock brake to standard conversion - JeepForum.com
post #1 of 7 Old 02-20-2011, 08:44 PM Thread Starter
91xjnostop
I am looking for information on converting a 1991 Jeep Cherokee from ABS to standard/conventional braking system. Has anyone done this? Can it be done? Is it worth it? Any advice helps!
91xjnostop is offline
post #2 of 7 Old 02-20-2011, 08:52 PM
the_weirdo
the_weirdo's Avatar
Here's for 97+ ABS pump removal, not sure how 91 differs: http://www.naxja.org/forum/showthrea...ight=abs*+pump
the_weirdo is offline
post #3 of 7 Old 02-21-2011, 02:16 PM Thread Starter
91xjnostop
thanx to all who replied . not to good at typing so i go slow. does anyone know if i will need to replace the pedal assembly, brake accuating rod if so which year will i need to retrieve these parts from?
post #4 of 7 Old 02-21-2011, 02:22 PM
jeeptorino68
1992 XJ Cherokee
you shouldnt need to replace those pieces,
pull all ABS fuses, and relays.
change the master cylinder, and the hardlines. and you are all done.
i have done it once, there was nothing specific that i remember,
i got a brake line flaring kit, and cutter, and bender, to manipulate the lines, and remove what wasnt needed.
Kyle
92 XJ 4.0 HO,AW4, NP242, 30" BFG AT, 1.75 spacer and ZJ coils, double cherokee leaf pack and 2 inch rough country shackles, 2.5 inch dnynomax exhaust, magnaflow cat, front hooks & rear hitch, gas skid, front skid, warn t-case skid, 99+ intake, bored TB
02 KJ Limited, 255 70 16s, front skid, LS/373 gears
jeeptorino68 is offline
post #5 of 7 Old 02-21-2011, 04:08 PM Thread Starter
91xjnostop
i may also mention that this 91 xj does not have a vaccume booster . the master cylinder is bolted directly to the firewall .so when the abs quit there is no assist . i have disabled the abs system and now the brakes are almost non excistant it is very scarry to drive
post #6 of 7 Old 02-21-2011, 05:54 PM
daurwid
1991 XJ Cherokee
I yanked my 1991 xj abs brake system about a year ago now. Had a buddy of mine do the work. We ninja'd a manual system from a 1996 cherokee sport, cylinder, pump, etc.
If you are getting no brakes at all, imo there's more wrong with your system than you think.
daurwid is offline
post #7 of 7 Old 02-21-2011, 06:01 PM
daurwid
1991 XJ Cherokee
Sorry to post again, but I forgot to mention one other thing. My buddy made it seem like making the new hard brake lines was the hardest part of the job. But it's worlds of difference going from ABS to standard. I had to take my ABS in for recall almost every 6-10 months for a complete rebuild and it would take 1-2 weeks. I got tired of it. Never given a free ride either to compensate, just a pain. So when I swapped my '91 engine for a '93, I had my buddy do the brakes at the same time.
daurwid is offline
anti lock brake system rapha XJ Cherokee Technical Forum 7 09-25-2009 06:04 PM
Check Anti Lock Brake Light Sarge75 XJ Cherokee Technical Forum 11 03-05-2008 01:01 PM
Anti lock brake axle kenpbuck XJ Cherokee Technical Forum 7 08-30-2005 11:02 AM
Anti Lock Brake Problem gerrya XJ Cherokee Technical Forum 7 04-15-2004 02:50 PM
Apparent Anti-lock brake malfunction 400lbguerrilla XJ Cherokee Technical Forum 2 11-13-2003 08:06 AM
