90 xj oil pressure sending unit help - JeepForum.com
post #1 of 3 Old 08-01-2013, 03:42 AM Thread Starter
Elrod90xj
1990 XJ Cherokee
So i was reading on some forums on here and alot of people say that their oil pressure sending unit was leaking oil. So i went to check mine out, it had a little oil on it but the wire coming out was hanging there not connected to anything! I looked all around the area and could not find any other disconnected wires. Does anybody know where the wire goes to from the unit? i was having problems with my oil gauge, and I think i might have found the problem. Now if i can just figure out where the wire needs to be reconnected I will be golden. Thanks!
Elrod90xj is offline
post #2 of 3 Old 08-02-2013, 07:58 PM
Mywrangler94
The reason you can't find the other end of that wire is because it goes into the wire loom.....you know that nice plastic covering over all those wires. Makes it look nice and neat...I would not doubt that its broken in there...
Mywrangler94 is offline
post #3 of 3 Old 08-04-2013, 01:07 AM Thread Starter
Elrod90xj
1990 XJ Cherokee
Is it just one wire running straight from the back of the gauge to the unit? If so, can't I just run a new wire from the gauge to the unit to avoid digging through all those looms?
