90 XJ Limited, Few Questions - JeepForum.com
post #1 of 2 Old 10-22-2005, 08:26 PM Thread Starter
LukeD
I just aquired a 90 Limited that has been sitting for about 8 months. After reading threads about poor idle and hard start I think I can solve the problem by cleaning the TB and IAC. However I now have a starter problem that I need some help on.
Earlier today I put a battery in it, it started up, porrly but started. It had a flat tire so I left where the jeep was and put a used tire ont he rim. I came back about 4 hours later and when i turn the key it won't crank, click, nothing. I found where the starter solenoid wire runs to and I think it is the problem because if I pull the wire off "the box" and touch it to the battery it turns over fine and starts. My problem is, is that I don't know what "the box" is. It is some sort of relay that one of the + battery wires runs to. It is on the passenger side just in front of the relay board. It has about 8-10 other wires running to it. I know what purpose it serves but I have no idea what it is called. I am going to buy a new on in the morning and go replace it if I knwo what to buy.
My only other question is, in order to clean the TB do I need to remove the TB from the intake or can I just remove the air cleaner hose and clean it fromt he top and if so can I clean the IAC also?
Thank you and glad to be a part of one of the most trafficed forums I could find
Luke Draper
Fresno, California
LukeD is offline
post #2 of 2 Old 10-22-2005, 10:36 PM
XJ4oh
1997 XJ Cherokee
Cant help you with the starter issue, but if the throttle body is really nasty, take it off and give it a thourough cleaning with sensor safe throttle body cleaner.. NOT carb cleaner, it will blow the sensors. Welcome aboard, to the best Jeep forum ever.
'97 XJ... 4.0 4x4 AW4. 2" budget boost w/t-case drop.
31x10.5 Cooper Discoverer ST's on 15x7 Cragar Soft 8's.
Intake, Ported TB, TB spacer, Super 40 Flowmaster.
Baja Aux. Lighting.
Green Jeep Club #185, Nowhere to Wheel Jeep Club member #1
'04 WJ - Columbia Edition - 4.7HO 2WD
XJ4oh is offline
Many technical questions about 89 Limited BreadnButter XJ Cherokee Technical Forum 18 08-20-2009 12:10 PM
Just bought an '89 XJ Limited...a few questions maalox XJ Cherokee Technical Forum 3 01-23-2007 07:32 AM
RIP noble Limited, questions for new Rig. FSTRDNU XJ Cherokee Technical Forum 18 06-23-2006 06:00 PM
'91 XJ 4wd Limited, Good price? + other misc. questions FASTnSPEEDY XJ Cherokee Technical Forum 6 09-20-2005 06:04 PM
2001 Limited - Questions and help ! creekxj XJ Cherokee Technical Forum 5 12-29-2003 11:40 AM
