90 cherokee runs rough - JeepForum.com
post #1 of 9 Old 06-15-2008, 12:42 AM Thread Starter
compfreak530
90 XJ runs rough
I just got a 1990 jeep cherokee limited 4.0 and it runs really rough. when i drove it home it ran great, but the next day it ran like crap. i found the fuel filter was fully clogged and replaced that with only a little improvement in performance.at first i thought it was a clogged injector so i ran some chevron with techron fuel cleaner through it and nothing. iv checked all the vacuum hoses and they all appear in good shape. as a random boredom test i unplugged each injector while running and found that the front 2 changed nothing, when i unplugged the back 4 the engine almost died. what can i do to test the front 2 injectors? how many volts should be coming out of the injector plugs? it idle`s rough and acceleration is also just as rough. i did a compression test and found that all 6 cylinders were at 125-130 psi.
compfreak530 is offline
post #2 of 9 Old 06-15-2008, 01:29 AM
littleblackXj
1993 XJ Cherokee
How long has its been since you replaced the spark plug, wires and distributor? I would start there.
littleblackXj is offline
post #3 of 9 Old 06-15-2008, 01:38 AM Thread Starter
compfreak530
i just it last week, i checked the spark plugs and they all appear to be clean burning. the truck did sit for about a year before i got it. iv herd you guys talk about sea foam. should i try that?
post #4 of 9 Old 06-15-2008, 02:03 AM
littleblackXj
1993 XJ Cherokee
I would. It costs about $10. Let your engine warm up and leave it running. Then pull off the intake tube and pour it directly into your throttle body. Just make sure to do it slowly and not let the jeep die. Then once you pour in about 1/3 of the bottle turn off the engine and let it sit for 5-10 minutes. Then when you start it up it will burn off all the carbon. Tack it up a bit for a few minutes then drive it around town like you stole it to burn off the carbon diposits.
It produces enough smoke to hide a tank, lol. I took a video of my jeep when i did it: http://youtube.com/watch?v=fwlgjOOl45E (back when it wasnt lifted ).
If you do kill it when pouring it into the throttle body, wait 5 minutes then start it up and then tack it up.
post #5 of 9 Old 06-15-2008, 02:38 AM Thread Starter
compfreak530
when you say about 1/3 into the engine. do you mean in the oil. or gas. or both?
post #6 of 9 Old 06-15-2008, 10:45 AM
littleblackXj
1993 XJ Cherokee
I mean pour 1/3 into the throttle body. Don't put it into your oil though. I would put the rest of the can into your gas tank.
post #7 of 9 Old 06-15-2008, 04:33 PM Thread Starter
compfreak530
I did as you said and got white smoke. not as much as your jeep but still alot. it still idles rough and hesitates on acceleration. after about 3k rpm it smooths out, could it be a vacuum leak?
post #8 of 9 Old 06-17-2008, 01:34 AM
littleblackXj
1993 XJ Cherokee
I am not sure what it could be but ill bump your thread for you
post #9 of 9 Old 06-17-2008, 07:14 AM
balloo93
Little Red Menace
balloo93's Avatar
1993 XJ Cherokee
How much gas was in it while it sat for a year? The gas more than likley went bad and you should go ahead and drop the tank and replace the fuel pump. Then run some seafoam in the gas to clean the fuel lines and injectors.
After that, I'd replace the plugs.
93 Sport
Beer is proof that God loves us and wants us to be happy............Ben Franklin
Specs in Profile.
balloo93 is offline
89 Cherokee Pioneer - Runs rough 4.0 john3416 XJ Cherokee Technical Forum 8 08-23-2016 08:22 AM
New to Jeepin: Bought 89 Cherokee, it starts and runs but runs rough and stalls in D stockli XJ Cherokee Technical Forum 7 04-29-2013 08:48 PM
89 cherokee runs rough and is missing sensor behind motor mount Robotaz600 XJ Cherokee Technical Forum 4 09-21-2009 04:00 PM
runs rough lrzmsr XJ Cherokee Technical Forum 5 05-04-2008 08:59 AM
1989 cherokee starts and runs rough Help!!! cjb91yj XJ Cherokee Technical Forum 6 10-28-2005 11:54 AM
