'90 Cherokee, New To Me, Questions... - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > XJ Cherokee Technical Forum > '90 Cherokee, New To Me, Questions...
Save on Selected Dynomax Exhaust Systems!Rough Country Lift Kits and Parts!All Bilstein shocks & struts - Lowest Prices Ever and
Unread 01-08-2015, 09:46 AM   #1
JeepHammer
Running On Empty...
1973 CJ5
'90 Cherokee Pioneer, Bone Stock...
Hadn't run in a year, previous owner said it got hit by lightening,
Took a buddy with me, turned out to be a crank sensor, which I understand is so common he took one with him when we looked at it...
Runs and drives now, But I have a couple of questions and could use a rundown on the fuel system, transmission, transfer case, ect. since it's about zero outside and I don't want to crawl under it!
Any maintenance specifics I need to do or look for?
A wheel bearing is going out in the rear axle,
Dana 35 as near as I can tell.
Any recommendations?
If it wasn't an issue, would any of you recommend swapping that D-35 for a Ford 9"?
It's got a miss at idle, just off idle,
Runs OK at 45 MPH and up, Anything specific I should be looking for?
Anyone know of an online service manual?
JeepHammer is offline   Reply With Quote Quick reply to this message
Unread 01-08-2015, 10:36 AM   #2
Paradise XJ
1988 MJ Comanche
Pick your model.
http://www.pacificcoastmanuals.com/j...e_manuals.html
Invaluable tips for the 87-90 (aka Renix)
http://comancheclub.com/topic/36382-...rs-renix-tips/
1990 XJ Laredo - White & Chrome
1988 MJ Pioneer - Metallic Green and Black
Paradise XJ is offline   Reply With Quote Quick reply to this message
