90 Cherokee Laredo Heater Hose Diagram!?!? - JeepForum.com
post #1 of 3 Old 01-03-2011, 06:13 PM Thread Starter
T-BirdJeeper420
1990 XJ Cherokee
Just need to know the routing path of the heater hoses running from the fire wall to the thermostat housing, including the check valve in the middle of them. Got a manual and it is not listed, everything else about the ENTIRE jeep is in that book, except that. A picture or diagram would be awesome, otherwise I will have to resort to trial and error, I hope someone can help with this simple yet frustrating issue. (Other notes: somthing is deff not hooked up right cuz the engine temp is usually from the 3/4 mark to the last white line on the gauge but will vary and stay within that range, also it has no heat, im sure all these problems are interlaced with having the hoses hooked up wrong)
T-BirdJeeper420 is offline
post #2 of 3 Old 01-03-2011, 09:02 PM
Saudade
1988 XJ Cherokee
Saudade is offline
post #3 of 3 Old 01-07-2011, 02:43 PM Thread Starter
T-BirdJeeper420
1990 XJ Cherokee
thanks a bunch, thats pretty close to how i have it but hopefully your info will help get the motor running a little cooler. =]
heater hoses
Looking for AC / Heater duct / switch diagram for 97 Cherokee. himagn XJ Cherokee Technical Forum 5 01-19-2011 12:14 AM
89 cherokee laredo fuse diagram needed PlainolBill XJ Cherokee Technical Forum 4 05-02-2010 06:17 PM
need help with heater hose routing around heater control valve jerry4570 XJ Cherokee Technical Forum 2 10-11-2009 12:35 PM
1997 cherokee laredo FLUX compasitor /heater /ac blower motor question jim49ers XJ Cherokee Technical Forum 1 11-08-2008 07:55 PM
vacume hose diagram?....aaarrghh trouttrooper XJ Cherokee Technical Forum 3 01-25-2007 07:58 AM
