90' Cherokee Idle Problem - JeepForum.com
post #1 of 8 Old 08-16-2002, 10:39 PM Thread Starter
ddoffroad
ddoffroad's Avatar
I recently had my throtle positioning sensor replaced but my rpm's sometime ride a little high and often when I start my Jeep they jump up to 3000 and wont go back down, but if I shut it off an restart it it will be ok. I have replaced the plugs and wires no more than a year ago....what can I do?
99 XJ - 4.0L HO, Rusty's K&N Intake, Rusty's 4.5" full suspension, 31x11.50 Swamper LTB's, 15x8 blk Daytona's, clear lenses, Warrior bumper w/ hooks
Down & Dirty Offroad:
My XJ site:
My Old XJ Site:
ddoffroad is offline
post #2 of 8 Old 08-16-2002, 10:41 PM
arpy
sounds like you still have a TPS problem
arpy is offline
post #3 of 8 Old 08-16-2002, 10:43 PM Thread Starter
ddoffroad
ddoffroad's Avatar
TPS
Throtle Positioning Sensor problem.....? The mechanic said it could need and injector cleaning......
My XJ site:
My Old XJ Site:
post #4 of 8 Old 08-16-2002, 10:56 PM
arpy
dirty injectors would cause power loss and maybe an erratic idle, but I don't see how it could cause it to rev to 3000 at startup. Mine did this (although only to 2000) until I replaced the TPS. I know you just replaced it, but maybe you got bad one? You want to fix this soon, 3000 at startup before the oil gets circulating will shorten your engine's life considerably.
by the way, check for moisture/corrosion/damage in the connector and wiring to the TPS, part could be good and these things preventing it from proper operation.
arpy is offline
post #5 of 8 Old 08-16-2002, 11:01 PM
arpy
and clean your injectors just for the hell of it, sometimes I'm full of sh@@, much like your injectors. Like I said I doubt thats your prob with the high revs, but if you haven't done it lately its a good idea anyway. I like Chevron Techron injector cleaner, the cheap stuff ain't gonna make it.
arpy is offline
post #6 of 8 Old 08-17-2002, 08:52 AM
williak
My 88 did just that prior to the TPS carping out. Mine would also drop to idle while you were going down the road (of course, this would only happen to the wife and not me, smart car). I replaced the TPS and the high idle and drop to idle problems stopped. I still have an low and irratic idle though, but thats another problem.
williak is offline
post #7 of 8 Old 08-17-2002, 10:44 AM
CruzNlife1
CruzNlife1's Avatar
Yeah i would check all wiring and connectors etc.... first, and as for the high idle at startup it could be when the new sensor was instlalled the idle skrew may have been touched
1989 Jeep Cherokee XJ LIMITED....2door.... Auto, NP242 4x4...
1996 Ranger Supercab....
1991 Mustang LX....
VERY SOON TO BE A BRAND NEW TJ OWNER, TRYING TO LEARN AS MUCH AS POSSIBLE RIGHT NOW !!
CruzNlife1 is offline
post #8 of 8 Old 08-18-2002, 12:38 AM Thread Starter
ddoffroad
ddoffroad's Avatar
TPS
Yeah, if it does come down to the TPS then I can get it replaced at the dealer I bought it from. Does anyone know the warranty on the Mopar TPS?
My XJ site:
My Old XJ Site:
1996 Cherokee idle surge/die problem... Julian1221 XJ Cherokee Technical Forum 8 10-08-2009 01:46 PM
cherokee idle problem hockeykid3824 XJ Cherokee Technical Forum 0 05-22-2008 03:10 PM
Rogh Idle in a 90 Cherokee Lmt. Vacuum Problem? kamspy XJ Cherokee Technical Forum 4 04-28-2008 08:29 PM
Strange Problem with my 2000 Jeep Cherokee-Unintended Acceleration, High Idle Hackworth75 XJ Cherokee Technical Forum 11 01-19-2008 02:36 PM
Unknown problem idle problem drunkenmonke XJ Cherokee Technical Forum 6 12-22-2007 10:56 AM
