89XJ Unibody queston - JeepForum.com
post #1 of 2 Old 09-25-2002, 05:01 PM Thread Starter
BadXJ
My 89 I use for some pretty serious off roading... The part of the uni body just right in front of the rear wheel wells is rusted out, so I broke a chunck of rust out and stuck my finger in the hole of the unibody and what did i find!!!!! AHHHHHHHHH its full of packed mud and crap. The only thing I can think of doing is eather using compressed air or a shop vac to get it out... I wish XJ were built on a frame somtimes..... Any help on this would be great and also warning.
89 XJ black 2 door -6" Tomken suspension lift, 33X12.5 Mud Kings, 4:56 RPs, Dana 35 w/ Detroit locker, Dana 30 front w/ Detroit locker, transfer case tailshaft eliminator, custom off-road driveshafts, AW4 trans w/ cooler, Tomken front and rear bumper SEE PIC SEE PIC @
WIFE:
98 ZJ Limited, Loaded RED/BLACK
BadXJ is offline
post #2 of 2 Old 09-26-2002, 10:22 AM
balloo93
Little Red Menace
balloo93's Avatar
1993 XJ Cherokee
I'd find a shop that'll 'patch' the hole, then open it up and get all that junk outta there. Once repaired, coat it with Por15. If you are really serious about it, get a couple of steel bristle brushes and resurface the whole underside and coat it all with Por15. Great stuff, resists all kinds of things and in stops rust. You could also use those wheel things that you put on a drill, they remove paint, so I'll assume undercoating, without any issues at all.
93 Sport
Beer is proof that God loves us and wants us to be happy............Ben Franklin
Specs in Profile.
balloo93 is offline
Will a 96 Comanchee Hood fit my 89XJ? CharlieMopps XJ Cherokee Technical Forum 6 12-04-2009 11:13 AM
I want to go doorless on my 89XJ gasmandave XJ Cherokee Technical Forum 3 09-12-2008 02:05 PM
Pray for my '89xj nhpso224 XJ Cherokee Technical Forum 3 01-27-2006 10:06 AM
Help Need 89XJ Starting to Run Like #/!% AngryDog XJ Cherokee Technical Forum 7 07-22-2005 01:06 PM
getting towed out with hitch queston or front axle queston. Roodki XJ Cherokee Technical Forum 12 04-06-2005 02:13 PM
