89 xj canary - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > XJ Cherokee Technical Forum > 89 xj canary
Yukon Ultimate 35 axle kit for c/clip axles with Yukon ZipSome Free shipping Coupon codesSPARTAN LOCKERS are on sale BIG TIME at ROCKRIDGE 4WD!
Unread 03-02-2015, 02:28 PM   #1
1989Cherokee4L
89 xj canary
Hi, both front wheel started squeaking turning left or right that is in tune with wheels rotating the faster wheels turn the faster the squeak that then falls silent over 30 mph, also front tyres scrub road on full lock turning both right or left, anyone know what this may be? Cheers
1989Cherokee4L is offline   Reply With Quote Quick reply to this message
Unread 03-02-2015, 05:11 PM   #2
CJ7-Tim
Real Jeeps have dents.
CJ7-Tim's Avatar
I would inspect the front axle u-joints and unit hub bearings.
Total US debt has increased by 70% under Obama, from $10.625 trillion on January 21, 2009 to $18.005 trillion January 1, 2015.
Progressive Liberalism: Bringing you new Healthcare ideas so wonderful, they have to include mandatory participation ......
CJ7-Tim is offline   Reply With Quote Quick reply to this message
Unread 03-03-2015, 01:35 PM   #3
1989Cherokee4L
Thanks, what grease do I use and how do I apply it, or are you thinking the units may need replacement?
Unread 03-03-2015, 04:26 PM   #4
CJ7-Tim
CJ7-Tim's Avatar
Your initial inspection will show you if the u-joints are greaseable or sealed, but if they are squeaking, they probably need replacing. The unit hub bearings are sealed, if worn they are replaced. You should consider replacing both u-joints and hubs to prevent the same disassembly two times.
Unread 03-04-2015, 08:09 AM   #5
1989Cherokee4L
Thanks, there also appears to be a shock absorbing item relating to steering as in line and leaking oil.
Unread 03-04-2015, 09:23 AM   #6
Paradise XJ
1988 MJ Comanche
That is a steering dampner/steering stabilizer. If leaking, replace...about $30.
1990 XJ Laredo - White & Chrome
1988 MJ Pioneer - Metallic Green and Black
Paradise XJ is offline   Reply With Quote Quick reply to this message
Unread Today, 12:08 PM   #7
1989Cherokee4L
The front axle u-joint on drivers side lhd 89 is movable by hand, when I rotate the front prop shaft by hand 1/2" the driver side front axle moves up and down as it rotates, does this indicate both hub bearing and axle u-joint require replacement, lesser point the grey plastic dust/dirt cover for the axle is also missing not sure what that part is called but also needs replacing.
Should I just focus on the one front axle u-joint that has failed that I can see, or do axle all u-joints and hub bearings, do fail at around the same time then?
The nearest workshop is 25 to 30 miles away I don't own a press, is it ok to drive there with the axle flopping movement, u-joint needle bearings all gone mostly orange powder, or should I put the jeep on a low loader truck to move it? Still drives just squeaks a lot so long as I don't hit a pothole in road?
Also I noticed when steering is on full lock, there is a sound in a burst of what sounds like gas being expelled?
