89 xj 4.0 misfire - JeepForum.com
post #1 of 3 Old 09-21-2011, 07:13 PM Thread Starter
Dsickness691
1991 XJ Cherokee
89 xj 4.0 misfire
Okay well today, i went out to re tighten my intake manifold bolts since it seemed to be idling high. I just did this a few months ago and dont drive it very often, the back half of bolts where all loose again with the very back one being able to be tightend with your fingers. When i started it back up, it was misfiring and wont stop. I know i have a very frayed cps sensor cable that when i move it, causes the jeep to cut off. Could this be my problem? It did this the last time i tigthend up the bolts but cleared up. A freind doing body work on it for me, also adjusted my idle screw without me knowing because it was idling high due to the intake being loose. I have a few broken vaccum lines as well but the jeep has run fine since i bought it like that. Any ideas? All answers are greatly apreciated
Dsickness691 is offline
post #2 of 3 Old 09-21-2011, 08:11 PM
FleshEater
2014 JK Wrangler
My XJ had a miss right around 2500 RPM's but once I hooked up all the proper vacuum lines it disappeared. Did you start in the middle of your manifold and tighten your bolts outward going top to bottom? Replace the broken cable as well...if all of these issues don't fix it then there is something else wrong.
2014 JKU Rubicon *DAILY DRIVER*
Gone but not forgotten; 2005 LJ *SOLD* 1987 XJ *SOLD* 2002 WJ *SOLD* 1995 ZJ *SOLD*
FleshEater is offline
post #3 of 3 Old 09-21-2011, 08:28 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Fix the vacuum lines and the CPS wiring as they are known problems. Why look elsewhere first?
cruiser54 is offline
misfire , ive done almost everything aleydic XJ Cherokee Technical Forum 44 01-18-2011 11:06 AM
misfire 1 and 3 toates89 XJ Cherokee Technical Forum 4 01-10-2011 06:16 PM
4.0 CEL, random cylinder misfire, cyl 2/5 misfire, and a loud engine noise at accel. Aran XJ Cherokee Technical Forum 13 03-17-2009 07:22 AM
Misfire cherokeeracer XJ Cherokee Technical Forum 0 06-25-2008 09:08 PM
Misfire...help!!! Paul Courbot XJ Cherokee Technical Forum 3 08-02-2006 12:49 PM
