89 injector swap - JeepForum.com
post #1 of 3 Old 10-20-2010, 07:22 PM Thread Starter
evilbill
89 injector swap
Hi everyone. I've done the search thing but I haven't seen a definate answer for my question. If you swap to the yellow top 4 hole injectors, do you or don't you have to use the later fuel rail with the higher fuel pressure regulator? some people have said no, and some have said yes. Inquiring minds want to know,
Thanks, Bill
evilbill is offline
post #2 of 3 Old 10-21-2010, 12:20 AM
rawk hard xj
1989 XJ Cherokee
I swapped in the 4-hole injectors on my '89 and kept everything else stock. Runs way better than it did before or than my other '89 ever did. But I've only been running for about 1,000 miles(Sarcasm). You may get more change using a H.O. intake due to its volume, but you could probably do the same thing with a throttle body spacer.
D.D. and wheelin' rig='89 Pioneer "Night-Train", used to be white '89 limited
I used to be XJ-NoDough (w/ 1688 posts) 'till I forgot my user name.
rawk hard xj is offline
post #3 of 3 Old 10-21-2010, 05:46 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Done 2 of my Renix Jeeps without changing the rail and about to do my third in the near future. The yellow tops give most benefit for two reasons:
They have the 4 discs which provide a better spray pattern.
They replace the POS Siemens-Deka injectors which came stock that were prone to leaking fuel from a seam and starting Car-B-Ques.
cruiser54 is offline
Neon Injector Swap hando XJ Cherokee Technical Forum 3 05-06-2011 10:31 AM
Post injector swap, ran great now lurches dover21 XJ Cherokee Technical Forum 6 09-08-2010 04:55 PM
Finished injector swap: Need to make sure i did it right. toates89 XJ Cherokee Technical Forum 2 03-06-2010 06:36 PM
injector swap. XJ98beast XJ Cherokee Technical Forum 0 03-01-2010 08:03 AM
injector swap boring96xj XJ Cherokee Technical Forum 1 08-18-2006 09:35 AM
