89 cruise component bad. Which one ?? - JeepForum.com
post #1 of 2 Old 06-09-2011, 11:48 AM Thread Starter
cardon
1989 XJ Cherokee
got my 89 cherokee a while back and am trying to bring it back to original condition. all purpose switch (handle) for wipers, lights, turn signals etc. had visable cut wires for cruise control going down steering column, so - replaced handle and wiring harness. next step was to find 15 amp fuse that manual indicated was in PDC. nowhere in engine compartment is a power dist. center. checking the index in the manual i cannot find it listed anywhere in index. before i go to the next step and check all vacuum sources i sure would like to find that fuse and replace , if necessary. Does anyone have any idea wher the cruise control fuse is located?? btw i checked all fuses at left kick panel (they're all identified and - no cruise listed.
Thanks for any thoughts or idea about this problem.
cardon is offline
post #2 of 2 Old 06-09-2011, 01:28 PM
1990JEEPXJ
1990JEEPXJ's Avatar
1990 XJ Cherokee
what manual said there was a fuse in the PDC? if it was a chiltons or haynes then it most likely isnt right. as you said, renixes dont have PDC under the hood like the HO models. i would simply move on to checking for vacuum leaks and make sure that the cruise control motor works still.
1990JEEPXJ is offline
Component Breakdown JWLane XJ Cherokee Technical Forum 3 10-01-2008 08:35 AM
Name The Component helijeep XJ Cherokee Technical Forum 5 07-27-2008 11:17 AM
cruise component interchangeability kpjoyce XJ Cherokee Technical Forum 1 04-18-2007 11:20 AM
Component locations Wayniac XJ Cherokee Technical Forum 8 12-31-2003 09:33 AM
missing component shylow XJ Cherokee Technical Forum 1 09-23-2003 12:14 PM
