89 Cherokee Sudden Loss Of Power. - Page 2 - JeepForum.com
post #16 of 29 Old 05-07-2009, 11:32 PM Thread Starter
HankyDanky
1989 XJ Cherokee
Originally Posted by 1deadeye View Post
Here is a link for the Renix ignition. It shows you testing for the renix ignition.
http://jeep.zerok.ru/index.php?page=21
Is your exhaust plugged. Bad cat.
Scott
Hey thats alot of great information!! Thanks alot man, gave me some good ideas. I have literally almost checked everything and have not found the problem yet. Cat, exhaust, every thing is new. Double checked it again by by pulling the front pipe and seeing if the power would come back. Nada. Thanks alot though.
1989 Cherokee 4.0l, Rubicon Express 4.5" XJ Super-Flex System, 33x12.50x15 KM2's
The XJ Rebuild-
People are always grabbing the handles, clutching the seat, or stomping an imaginary brake peddle when we're out having fun.
HankyDanky is offline
post #17 of 29 Old 05-08-2009, 08:46 AM
dover21
Are the brake pads in contact with the rotors? That kind of friction could definitely hamper any smooth and powerful acceleration.
dover21 is offline
post #18 of 29 Old 05-08-2009, 08:50 AM
cbordea
yeah, i had a problem similar one time and realized my ebrake was on ;-)
88 MJ I6 4x4 Stock my hauler - Sold
98 XJ I6 4X4 Stock my son's DD
06 12V Purple Barbie Jeep my daughter's DD :-)
cbordea is offline
post #19 of 29 Old 05-08-2009, 11:32 AM
88XJSport
88XJSport's Avatar
1988 XJ Cherokee
What is the input/output voltage on the TPS, and is it adjusted according to the FSM?
What is your PSI at the fuel rail? 31psi is minimum needed.
88XJSport is offline
post #20 of 29 Old 05-08-2009, 11:35 AM
Finallyajeep
Hows your air filter?
Firefighters Jeep Club
Finallyajeep is offline
post #21 of 29 Old 05-08-2009, 11:39 AM
MA88XJDude
sounds like when my cat was getting clogged
88' YJ/CJ Turbo Diesel
MA88XJDude is offline
post #22 of 29 Old 05-08-2009, 11:53 AM
88XJSport
88XJSport's Avatar
1988 XJ Cherokee
He said his was clear.
post #23 of 29 Old 05-08-2009, 12:54 PM
1deadeye
1988 XJ Cherokee
Any time. Let us know what you find. So I can had it to my ever forgetful memory.
Scott
1deadeye is offline
post #24 of 29 Old 05-08-2009, 02:01 PM Thread Starter
HankyDanky
1989 XJ Cherokee
No the brakes suck as it is with the 33's so thats not it.
lol, E-Brake is def. not on
I got a reading of .827 when you divide the output by the input and optimal is .830. Can be between .825 and .835
PSI was 41 so its all good.
Air filter is clean.
The XJ Rebuild-
post #25 of 29 Old 03-11-2011, 09:39 AM Thread Starter
HankyDanky
1989 XJ Cherokee
Figured I would update this, when I installed the new TPS there is a bar that moves when the throttle opens/closes which in turn provided the correct air/fuel ratio. The lever was not catching on the bar, which in turn made the computer think that the throttle body was closed all the time. Result? NO POWER! lol, So make sure if you install one, that it is put in correctly. Thats all!
The XJ Rebuild-
post #26 of 29 Old 03-11-2011, 11:32 AM
Topgun514
1988 XJ Cherokee
I did this too...duhhh
but I hope 2 years later he figured out the issue.
87 XJ pioneer-Totalled
96 XJ Sport- Sold
Now: 88 RENIX 4.0 XJ, Project Overlander
3.5" Lift, RE SF LCA's with skids, 31x10.50R15 Duratracs, ARB Roofrack, Custom Bumper, Glasspack, Bored TB, Custom seats
Topgun514 is offline
post #27 of 29 Old 03-11-2011, 09:01 PM Thread Starter
HankyDanky
1989 XJ Cherokee
Ha, yeah it didn't take me more than a couple days and a lot of headaches to figure it out. Just haven't been on the forum in forever..
The XJ Rebuild-
post #28 of 29 Old 03-11-2011, 10:48 PM
my2monkeys
1989 XJ Cherokee
So the tang on the TPS wasn't on the correct side of the Thottle body tang?
I'm surprised it accellerated at all.
It shifted thru gears with an at idle input to the TCU is also something I wouldn't expect.
Thanks for posting up with your fix.
wifes 95zj 4.0 42re np249 201,000mi
mine 89 xj 4.0 aw4 np242 445,000mi
nephews 98 zj laredo 4.0 2WD 213690mi
my2monkeys is offline
post #29 of 29 Old 03-11-2011, 11:03 PM Thread Starter
HankyDanky
1989 XJ Cherokee
Yeah it was really strange.. When you put the TPS in, you have to almost angle to catch that bar. If you don't it will sit on top of it and will not do ya any good.
The XJ Rebuild-
89 Cherokee 4.0 severe power loss & backfire! mondojeep XJ Cherokee Technical Forum 16 06-05-2014 10:08 AM
engine sudden loss of power and strong fuel odor Codetalker XJ Cherokee Technical Forum 4 09-07-2009 10:30 PM
Sudden loss of power MN_Sasquatch XJ Cherokee Technical Forum 1 08-30-2006 02:23 PM
1990 Cherokee Pioneer Power Loss osurferx XJ Cherokee Technical Forum 5 08-15-2006 05:24 PM
Sudden Power Loss? lordsith XJ Cherokee Technical Forum 5 11-19-2004 03:33 PM
