89 cherokee!! HOW DO I get the alternator out???? - JeepForum.com
post #1 of 3 Old 03-13-2003, 01:56 PM Thread Starter
cherokeeorley
I am having a problem finding the right bolt to lossen, or place to remove my belt. I can't figure out how to loosen the belt! This is a 4.0 1989 cherokee Larado.
My 93 cherokee has a small wheel next to the thermostate houseing(that lossens it), but this one I can't figure out. Also will I need to pull the radiator, or anything else to get to it. I know this is something simple, but I have not had much time to fuge with it.
Thanks for any helpful comments:
Mike Orley. 93 Cherokee 5"lift 32"AT tires,Outlaw 15" rims. Flowmasters, t-bar, quick disconects, clear euro-rear taillights, clear corner f-markers, brush gd. transmission lowering kit, shaved fender, all the goodies
cherokeeorley is offline
post #2 of 3 Old 03-13-2003, 02:48 PM
MJR
MJR's Avatar
1988
The power steering pump needs to be loosened. There is one 13mm pivot bolt at the top front, one 13mm nut under in the front (adjuster lock nut), two 13mm in back of the pump, and then loosen the adjuster bolt on the driverside also a 13mm. Its a little easier with the aux fan out. That will loosen the belt. Then the alt comes out from underneath with 10, 13, 14, 15mm bolts/nuts. You have to loosen the stamped steel bracket to make it easier to get out. I would disconnect the battery before you pull the alt just to be safe.
"Got Groceries"
88 Jeep Wagoneer
MJR is offline
post #3 of 3 Old 03-13-2003, 11:11 PM
ChrisinVA
Ditto. Couldn't have said it better myself.
ChrisinVA is offline
better alternator for my 88 4.0 cherokee DirtyDanNY XJ Cherokee Technical Forum 5 08-26-2009 02:53 PM
cherokee alternator ? newbs XJ Cherokee Technical Forum 4 08-13-2009 10:03 PM
newer alternator in older cherokee in XJ Jenyus425 XJ Cherokee Technical Forum 7 03-04-2009 02:53 PM
94 cherokee alternator replacement jlsporty XJ Cherokee Technical Forum 4 01-11-2007 05:42 PM
