89 Cherokee Electrical Issue - JeepForum.com
post #1 of 6 Old 09-16-2010, 03:12 PM Thread Starter
tball32
1989 XJ Cherokee
Looking for some suggestions on finding a the problem with my cherokee's wiring. I was driving to work early one morning and my jeep just shut down engine stoped and the dash went dark. The headlights still worked but radio and such were dead. Clutched and coasted for a while and popped it and rolled the engine but no fire, coasted a while longer clutched and she fired up dash came back on and away we go. Two days later the electric cooling fan stoped workin it was a broken wire so that was repaired everything working again. Then another two days later pulling down the drive to work the jeep died again dash went blank and its never fired again. Something must have shorted because it fryed one of the fuseable links to one of the main red power wires by the battery, Repaired that but was not the whole problem. Any suggestions on were else to look for a problem or any possible solutions that any one can think of.
tball32 is offline
post #2 of 6 Old 09-16-2010, 04:21 PM
talentjeep
1987 XJ Cherokee
freshen all of your grounds.
what's the condition of your fusebox? under the dash.
have your battery and alternator tested.
'87 XJ Pioneer with 32" KM2s, etc.
talentjeep is offline
post #3 of 6 Old 09-17-2010, 03:58 PM Thread Starter
tball32
1989 XJ Cherokee
i am working on tracking down the all the grounds, fuse box looks pretty good under the dash and it didnt blow any of the fuses during this process. The battery is good and the alternater as charging good right before this all happened thanks for the ideas I get all the grounds tracked down and im not sure where to look next.
tball32 is offline
post #4 of 6 Old 09-17-2010, 04:43 PM
jk4x4
1988 XJ Cherokee
Check the main wire harness plug on the firewall unplug clean and reconnect it. I would check your crank sensor also.
jk4x4 is offline
post #5 of 6 Old 09-17-2010, 06:28 PM
talentjeep
1987 XJ Cherokee
Originally Posted by balloo93 View Post
C101
Disconnect the battery and just be careful. I have read about people hard-wiring the connections to get away from the plug as mentioned in this JPmagazine article:
C-101
For once, we aren't talking about Trasborg's pile of Jeepsters. We've hit on this one before in these pages, but it is worth covering again. The '87, '88, and some of the '89 model years had this wonderful connector, called the C-101 connector. It connected all the wiring from the inside of the Jeep to the wiring outside of the Jeep. The problem is, it is over 20 years old and is mounted right at the top of the firewall where all the water cascading off of a newly-opened hood can go. If all that wasn't enough to prove a point, there is a TSB from Jeep way back in '89 that provided a crankshaft sensor bypass kit and instructions to get around the C-101 connector and keep the Jeep running. Most of the '89 models, and all of the '90 models didn't even have the C-101, they just went to a rubber grommet passing the wires through the firewall.
Prevention: You can build a rain shield for it, or just be aware of it when you open the hood. Periodic disassembly, cleaning, dielectric-greasing, and reassembly also help the issues.
Cure: Get rid of it. Solder all the wires from the inside of the Jeep to the corresponding wires from the outside of the Jeep and heatshrink it. All the issues will be gone forever. The risk is if you cross wires just once you can fry stuff pretty easily.
from another thread. helped with some of my past issues as well.
post #6 of 6 Old 10-14-2012, 07:35 PM
styxmalone
1989 XJ Cherokee
Have you checked the fusable links by the battery
styxmalone is offline
cherokee won't start , wiriing harness , wiring , wiring harness melted
Electrical Issue 2007 Cherokee KJ2657 XJ Cherokee Technical Forum 1 05-11-2010 12:08 AM
89 cherokee laredo electrical issue 89cherokee352 XJ Cherokee Technical Forum 12 01-20-2010 06:10 AM
'01 Cherokee electrical issue gepetto5 XJ Cherokee Technical Forum 1 07-31-2009 01:57 PM
98 Cherokee Electrical Issue Jeff19 XJ Cherokee Technical Forum 3 01-15-2007 10:57 AM
'99 Cherokee Electrical Issue bonji XJ Cherokee Technical Forum 2 10-31-2005 11:23 AM
