89 Cherokee 4.0 severe power loss & backfire! - Page 2 - JeepForum.com
post #16 of 17 Old 04-27-2010, 12:52 AM
talentjeep
1987 XJ Cherokee
i believe the Renix system doesn't engage fully until 300 RPM to prevent dry starts. computer was designed by an aircraft manufacturer so they wanted to prevent damage to the engine.
once you get the hang of it you can let off the key half a second before it fires and save a few starter turns. almost an art form in an of itself.
thanks for posting the fix! many people just run off and forget about us XJ lovers and leave us wondering what happened.
'87 XJ Pioneer with 32" KM2s, etc.
talentjeep is offline
post #17 of 17 Old 06-05-2014, 11:08 AM
Jeep93cherokee
1993 XJ Cherokee
Good idle but no power or acceleration
Hey guys big issue even the mechanics an my self are clueless an can't figure it out but here's the problem has good idle an once you accelerate it throws a fit back fires an has no power I changed the cap,rotor,wires,plugs that didn't fix it so I put a fuel filter on it still didn't fix it so my boss came over an we tried to pull codes an nothing so he said start it up so I did an he unplugged the crank shaft sensor an bam!! It ran like a champ for 2 days while we ordered a new one but when I put the new one in it still didn't fix it so he said it had to be the computer so I replaced that still nothing an it has no vacuum leaks cleaned all the grounds an still nothing tried to reset the computer runs good for 5 seconds an does the same things anyone have a idea or hint to throw out this things got me confused to no end
Jeep93cherokee is offline
89 Cherokee Sudden Loss Of Power. HankyDanky XJ Cherokee Technical Forum 28 03-12-2011 12:03 AM
Serious problem with my '92 Cherokee--severe power-loss shuddering and lurching! Rogue-Sasquatch XJ Cherokee Technical Forum 4 05-19-2010 08:20 AM
1995 XJ Cherokee, exhaust leak/power loss 221kJeep XJ Cherokee Technical Forum 0 10-02-2009 03:43 PM
1987 Cherokee total loss of power WhrexKing XJ Cherokee Technical Forum 15 01-12-2009 01:52 AM
1990 Cherokee Pioneer Power Loss osurferx XJ Cherokee Technical Forum 5 08-15-2006 06:24 PM
