89 cheroke 4.0 vaccum diagram - JeepForum.com
post #1 of 8 Old 03-19-2002, 12:02 PM Thread Starter
Travis
Post 89 cheroke 4.0 vaccum diagram
Does anyone have the exact vaccum diagram for this year cherokee (89)? I think it is most of my problem. Can someone take some close up pics of the vacuum hoses under the hood maybe? I realy need to get this crap straightened out. I have found one place on line with a diagram but it is nothing like mine. Thanx
Travis is offline
post #2 of 8 Old 03-26-2002, 09:52 AM Thread Starter
Travis
Post
Anyone?
Travis is offline
post #3 of 8 Old 03-26-2002, 11:16 PM
jcmiley
Post
Just curious what your original problem was? I have an 89 4.0 that does great around town, but has absolutely no guts at highway speeds. I cant even use 5th gear. What pics are you needing and maybe I can e-mail them to you.
James
Anemic 89 XJ
jcmiley is offline
post #4 of 8 Old 03-27-2002, 09:29 AM Thread Starter
Travis
Post
Mine to does fine around town. I get onto the pkwy and speed up to around 70. It does fine all the way up to 70. Once I get to 70 and cruise at 70 for a while it starts cutting out. It will run fine for a few seconds then jerk a little. It feels like it would if you pumped the gas pedal while cruising down the highway. That's the best i can describe it. I would like a pic of the vaccum diagram or a close up pic of a 4.0 engine the same year or close. I think it's either the vaccum hoses or the fuel pressure. I figured I would check the hoses first. If you get your's fixed let me know what you did. Thanx
Travis is offline
post #5 of 8 Old 03-27-2002, 10:34 AM
Flanz
Post
I have some pics of my '88 I6 for you just tell me how you want me to get them to you.
Your problem might be the valve springs. If they get weak they cant close the valves fast enough at high RPMs and this causes erratic vacuum (a vacuum gauge needle will jerk all over the place.
'88 XJ 4.0L Rusty's cat back exhaust with Flowmaster
Flanz is offline
post #6 of 8 Old 03-27-2002, 12:32 PM Thread Starter
Travis
Post
The motor is rebuilt and the head/valves were checked and replaced. E-mail me the pics to travr6@yahoo.com if you don't care. I may be able to see from them whether or not mine are right
Thanx
Travis is offline
post #7 of 8 Old 04-02-2002, 04:54 PM
Flanz
Unhappy
That address didn't work. Do you still want them?
Flanz is offline
post #8 of 8 Old 04-03-2002, 07:49 AM Thread Starter
Travis
Post
I don't see why it would not work. Yea I still want them. Try again travr6@yahoo.com or irish1234@hotmail.com
thanx
Travis is offline
NP 231 vaccum switch electric or vaccum mcluvin2k5 XJ Cherokee Technical Forum 1 03-08-2009 12:10 AM
Need pic or diagram of Vaccum lines for 88 MJ Fiend101 MJ Comanche Technical Forum 4 02-12-2009 11:12 PM
'88 cheroke sometimes key won't come out cygnus58 XJ Cherokee Technical Forum 3 07-03-2007 10:18 PM
New To Me 90 Cheroke WILSONRIVERFISH XJ Cherokee Technical Forum 9 06-23-2007 01:39 AM
92 Cheroke` gosling1 XJ Cherokee Technical Forum 10 06-12-2003 11:04 AM
