'89 to '91 wiring - JeepForum.com
 1Likes
post #1 of 20 Old 09-14-2017, 03:17 PM Thread Starter
cl700
1989 XJ Cherokee
'89 to '91 wiring
So I have an '89 jeep Cherokee Laredo. Recently I bought a '91 Laredo for parts. The wiring in the '89 has started to take a crap so I wanted to replace it with the wiring from the '91. How hard of a swap is this? What tips do you have for me before starting?
Sent from my iPhone using Tapatalk
Ride like its your last
cl700 is offline
post #2 of 20 Old 09-15-2017, 05:50 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Don't do it. Really alot different.
If you own a Renix Jeep, you must check this out:
My Jeep technical photos:
cruiser54 is offline
post #3 of 20 Old 10-10-2017, 08:42 PM Thread Starter
cl700
1989 XJ Cherokee
I actually went ahead with it. I have everything swapped in. Only thing now is I donít have spark
cl700 is offline
post #4 of 20 Old 10-10-2017, 09:56 PM
un4gvn1
un4gvn1's Avatar
1988 XJ Cherokee
You asked, and got an answer from one of the top (if not the very top) Renix guru & went ahead anyway?
Never, but never doubt cruiser54!
Working with cars is a little like a really awesome date: you start out expecting this to be something simple and straightforward; four hours later you're laying under her, panting and cursing, and things are a lot more complicated than you thought.
un4gvn1 is offline
post #5 of 20 Old 10-10-2017, 10:09 PM
Nick05
1994 XJ Cherokee
Did you swap ecm and all sensors? If not, swap wires back and then replace the wires that were originally on the jeep with new wires where needed.
Nick05 is offline
post #6 of 20 Old 10-12-2017, 03:40 AM Thread Starter
cl700
1989 XJ Cherokee
I swapped all sensors and things that did not allow the new harness to work with the old. And I know I asked a question and then went ahead with it anyway, however at the time I thought it to be worthy to do. Now I see I should have just replaced wires where I could in the truck
cl700 is offline
post #7 of 20 Old 10-12-2017, 06:28 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
WHAT ABOUT THE FLYWHEEL/FLEXPLATE????????
If you still have the 89 flexplate in it, it won't work with the HO CPS and an HO flywheel won't work with a Renix CPS.
post #8 of 20 Old 10-12-2017, 11:42 AM Thread Starter
cl700
1989 XJ Cherokee
No I didnít swap the flex plate out. The motor has been rebuilt about 1,000 miles ago if that even. And I meantioned to them about this swap before so I could go to the non renix intake and they said everything should work just fine
cl700 is offline
post #9 of 20 Old 10-12-2017, 11:45 AM
Nick05
1994 XJ Cherokee
No I didn’t swap the flex plate out. The motor has been rebuilt about 1,000 miles ago if that even. And I meantioned to them about this swap before so I could go to the non renix intake and they said everything should work just fine
They aren't cruiser.
Nick05 is offline
post #10 of 20 Old 10-13-2017, 06:39 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Who is "they"?
Better have a peek at that flexplate.
If it has little rectangles in it all the way around, it's a Renix flexplate.
If it only has a few every 120 degrees, it's an HO.
post #11 of 20 Old 10-15-2017, 12:21 PM Thread Starter
cl700
1989 XJ Cherokee
Alright, well Iíve got spark now but the thing still wonít fire. So now Iím lost
cl700 is offline
post #12 of 20 Old 10-15-2017, 12:44 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
How did you get this spark?
post #13 of 20 Old 10-15-2017, 04:47 PM Thread Starter
cl700
1989 XJ Cherokee
Well I pulled the crank shaft positioning sensor and cleaned it and re hooked it up
cl700 is offline
post #14 of 20 Old 10-15-2017, 10:02 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Still don't know which flexplate you have......
Hate to say I told you so, but I did. And you ignored my advice.
Now, you post things that don't answer our questions and plea for help. I think I need to unsubscribe from this hopeless thread.
I feel like I'm talking to a frickin brick wall. Cheers!!!
un4gvn1 likes this.
post #15 of 20 Old 10-15-2017, 11:44 PM
un4gvn1
un4gvn1's Avatar
1988 XJ Cherokee
>>Bingo!<<
If you still have your old wiring harness, start putting it back. Otherwise, pull the engine & swap out your flexplate. (and hope that's the only problem)
SMH
un4gvn1 is offline
