89 4.0 XJ so weak I can't use 5th gear - JeepForum.com
post #1 of 9 Old 03-21-2002, 12:03 PM Thread Starter
jcmiley
Post 89 4.0 XJ so weak I can't use 5th gear
Forgive my lack of knowledge guys, but this seems wrong. I have a 89 XJ that has absolutely no power at all. 4.0 and manual transmission. It feels as if it is not getting in advance in the ignition timing, but I am not sure. I had a 96 4.0 and that thing was awesome. My 89 has to stay in 4th gear at highway speeds with the accelerator on the floor just to maintain 60-65 mph.
Any takers?
Anemic 89 XJ
jcmiley is offline
post #2 of 9 Old 03-21-2002, 01:50 PM
CB89XJ
Post
Make sure the cat converter isn't clogged. This would really reduce the power.
Colin Beatty
'87 YJ, built 351W, T-18, NP-205, SOA, SRS, 35x12.50 ProComp MT's, cage, winch, Tomken bumper/carrier, d44/9"
www.bmja.org
CB89XJ is offline
post #3 of 9 Old 03-21-2002, 06:59 PM Thread Starter
jcmiley
Post
Thanks for the reply, but it has a brand new cat on it. The thing acts like it is not getting in advance in the timing.????
James
Anemic 89 XJ
jcmiley is offline
post #4 of 9 Old 03-21-2002, 08:00 PM
blue93xj
Post
I have had two aftermarket cats on another vehicle die in a very short time after install. If it was not a factory part I might be suspicious.
If the timing is not advancing it should show symptoms in all gears not just 5th.
good luck
blue93xj is offline
post #5 of 9 Old 03-22-2002, 12:40 AM Thread Starter
jcmiley
Post
bump
Anemic 89 XJ
jcmiley is offline
post #6 of 9 Old 03-22-2002, 08:10 PM
Brian Peake
Cool
Parking Break On Buddy?
Brian Peake is offline
post #7 of 9 Old 03-26-2002, 11:12 PM Thread Starter
jcmiley
Post
How does Jeep advance the timing on the 4.0? Is it vacumn or all done through the ECU. I checked the cat (gutted it!) and still nothng. Is anybody else experiencing similar symptoms?
TIA
James
Anemic 89 XJ
jcmiley is offline
post #8 of 9 Old 03-30-2002, 01:34 PM Thread Starter
jcmiley
Post
I think I may have found at least part of the problem. The tires on it are 235/75/r15's. My neighbors jeep has 215/75/r15. Also found out the other night that my speedo is @ 10 mph slower than actual speed. ie.. says 65 while doing 75. By screwing up the final drive ratio so bad, I figure that is why I'm not in my power band. It would be like you guys putting your xj into 5th while only going 40 mph...
any takers?
Anemic 89 XJ
jcmiley is offline
post #9 of 9 Old 03-30-2002, 01:48 PM
Travis
Post
Nah. I have 235's also and mine has power well beyond 65 or 75. I just can't seem to get that sputter out of it. I think it's my vacuum hoses but I can't find a diagram anywhere. 89' cherokee 4.0
Travis is offline
98 XJ weak start Atari.fan3000 XJ Cherokee Technical Forum 17 06-04-2014 10:47 AM
Weak spark? Lone Star XJ XJ Cherokee Technical Forum 5 05-31-2009 08:06 AM
4.0 very weak triplej1954 XJ Cherokee Technical Forum 2 01-03-2009 08:23 PM
weak steering? bikedude189 XJ Cherokee Technical Forum 3 04-06-2008 10:43 PM
brakes are weak fordpower XJ Cherokee Technical Forum 2 06-07-2007 11:30 PM
