88 XJ overheating issue - JeepForum.com
post #1 of 19 Old 07-07-2009, 07:30 AM Thread Starter
rust-r-bust
1988 XJ Cherokee
ok so i have replaced the water pump, upper adn lower coolant lines, radiator cap, thermosdadt, and have flushed the system.....it is a closed system and it constantly overheats....any other ideas?
1988 jeep cherokee with 6.5" lift and 31's
1992 jeep cherokee with 2" lift and stock tires--RIP
rust-r-bust is offline
post #2 of 19 Old 07-07-2009, 08:20 AM
longtravel1
1989 XJ Cherokee
Have the radiator rodded out by a repair shop. Also it is a closed system, on my 89 I had to burp it several times even after it was warm. Try turning on the heater and continue filling.
longtravel1 is offline
post #3 of 19 Old 07-07-2009, 03:35 PM Thread Starter
rust-r-bust
1988 XJ Cherokee
ok update...it is back flowing.....that is what i was told my my buddy.....
i am going to try to put in a open system...anyone have a write up on how?
post #4 of 19 Old 07-07-2009, 03:42 PM
bjones71087
Happen to grab the wrong water pump? some of the 4.0s spun a different way.
bjones71087 is offline
post #5 of 19 Old 07-07-2009, 06:24 PM
Fir3Chi3f
1987 XJ Cherokee
when you say it is overheating, is it getting into the red or blowing coolant out of the cap? Usually these things run pretty hot 210F Many have reported.
Fun needs a full tank of gas
My headlining
Fir3Chi3f is offline
post #6 of 19 Old 07-07-2009, 10:53 PM Thread Starter
rust-r-bust
1988 XJ Cherokee
it is blowing out the cap....and it spins the same way.....im going to try and clean out the radiator
post #7 of 19 Old 07-07-2009, 10:57 PM
lifted89xj
1989 MJ Comanche
my 89 threw a fit the other week.
i flushed the system and re filled with new antifreeze
removed my thermostat
and went to the junk yard and got a electric AC fan and installed it. it fits right in place with the engine fan shroud. looks clean too.
on the highway it will run 110* but sometimes in town when its hot out it will got ot 210*
it always ran 210* before i had the 220-240* spike from pulling a trailer
Alpinestars Racing Ahead....
HOOD VENT/ LOUVER SALE Click Below
lifted89xj is offline
post #8 of 19 Old 07-08-2009, 12:06 AM Thread Starter
rust-r-bust
1988 XJ Cherokee
i have flushed it about 5 times by now...new thermostadt...and i dont think the little fan will make that much of a difference....
post #9 of 19 Old 07-08-2009, 12:28 AM
Ac1d
Probably just needs to be burped, if you have a radiator cap its easy. I installed a radiator cap into my upper radiator hose for pretty cheap. Just open it up, turn the rig on and let it run. Just keep filling it till the fluid level doesn't go down anymore. Then top off the overflow bottle.
Ac1d is offline
post #10 of 19 Old 07-08-2009, 11:37 PM Thread Starter
rust-r-bust
1988 XJ Cherokee
it is a closed system so i can only put fluid in the resovior....there is no cap by the uper hose....so i need more ideas....if i dont get anythign soon im going to redo the head and a bunch of other deep engine stuff...
post #11 of 19 Old 07-08-2009, 11:49 PM
SoloCamo
1988 MJ Comanche
Did you replace the clutch fan?
Engine: Cutout+Insulated Airbox | Ford Design II 19lb injectors
Suspension: Gabriel VST Shocks
Tires: Firestone "Firehawk Indy 500" 235/70/15's
SoloCamo is offline
post #12 of 19 Old 07-09-2009, 12:03 AM Thread Starter
rust-r-bust
1988 XJ Cherokee
is that the black electrical fan? if so then not yet...but it cant make that much of a difference...can it?
post #13 of 19 Old 07-09-2009, 12:43 AM
balloo93
Little Red Menace
balloo93's Avatar
1993 XJ Cherokee
It sounds like the root cause of your overheating may be air in the system. You need a better cap and bottle to maintain the pressure of the coolant system and you need to follow the burbing proceedure.
A new mechanical clutch for the fan would be a wise investment as well.
93 Sport
Beer is proof that God loves us and wants us to be happy............Ben Franklin
Specs in Profile.
balloo93 is offline
post #14 of 19 Old 07-09-2009, 12:46 AM
1984XJ
I feel ya, the same was happening to me, The person at the Safety and Emissions place over heated it, and i guess it ruined the thermostat. I filled the radiator threw the hose, because i also dont have a cap, i filled the hose up, and put my mouth over it and blew the coolant down into the radiator, and it fixed, good luck!
.,_______.o_o.
//_|__l__,\___\,___
l_--\__\__l----[]llllll[]
_(o)_)____(o)_)--o)_)
Daily Driver Jeep #16
Utah Jeep'n
1984XJ is offline
post #15 of 19 Old 07-09-2009, 07:16 AM Thread Starter
rust-r-bust
1988 XJ Cherokee
i will try and burp it today and i will also fab up a better bottle made out of a better material than the crappy plastic bottle it comes with....
overheating issue!!!! jeepxj91 XJ Cherokee Technical Forum 14 07-30-2008 11:42 AM
Overheating issue or not?? XbajaJeepX XJ Cherokee Technical Forum 3 11-01-2007 05:58 AM
overheating issue with ac on mekrew XJ Cherokee Technical Forum 13 08-08-2006 02:13 AM
Overheating issue BayouBengal85 XJ Cherokee Technical Forum 3 09-19-2005 11:55 PM
Please Help.... Overheating Issue???? 01JeepXJ XJ Cherokee Technical Forum 5 08-08-2005 01:40 PM
