88 XJ Highspeed engine problems - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > XJ Cherokee Technical Forum > 88 XJ Highspeed engine problems
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineSavvy Aluminum BumpersThe RuffStuff "I can't go to EJS" Sale!
Unread 01-11-2014, 11:31 AM   #1
WeaponTech
So, Iv found a few vac leaks. I fixed them. Iv put new plugs, wires, cap and rotor. Iv cleaned the ISV and throttle body.
My problems is... that at speeds above 50kph, It seems to be lagging. And when I get above 100kph, I can feel a stumble. Like its misfiring.
It will start fine, hot and cold. It idles fine hot and cold.
I just don't know where else to look. And I don't want to just go around replacing sensors all willy-nilly that's expensive.
WeaponTech is offline   Reply With Quote
Unread 01-12-2014, 10:00 AM   #2
Paradise XJ
1990 XJ Cherokee
Isv?
1990 XJ Laredo - White & Chrome
1988 MJ Pioneer - Metallic Green and Black
Originally Posted by Caner. View Post
I slide it in and then when I pull, it works fine.
Paradise XJ is offline   Reply With Quote
Unread 01-12-2014, 11:59 AM   #3
WeaponTech
Idle Stabilizing Valve
