88' XJ Cranks, Won't Turn Over After Stopping - JeepForum.com
post #1 of 6 Old 11-07-2008, 12:35 PM Thread Starter
Motorcharge
I've got an 88' XJ Laredo.
Brand new ignition module and coil.
It runs and runs perfectly when it does, but when I stop I have to open the hood for 5-10 min before it will start back up. It'll crank, but it just won't start right up if I've been driving. I drove about 100 miles today before stopping with zero problems, stopped and went inside my aunts house for about 20 min and it wouldn't start. Wasn't over heated, all my fluid levels are fine, battery is fine.
above is a repost, but something I just thought of, this only started happening after I ran out of gas. It ran perfectly out to the inspection station about 50 miles from me and back. I ran out of gas like a block from the gas station. Pushed it there, filled up, started right back up. I got home and went to leave about 30 min later and its been happening ever since.
Also, I was sitting at a light the other night and it shut off and wouldnt turn back over for another 15 min or so. (apparently people dont understand hazard lights )
Motorcharge is offline
post #2 of 6 Old 11-07-2008, 02:43 PM Thread Starter
Motorcharge
post #3 of 6 Old 11-07-2008, 03:09 PM
JTruel
Is it cranking and not starting? Or not cranking at all when you turn the key?
2000 XJ Classic
2005 LJ
JTruel is offline
post #4 of 6 Old 11-07-2008, 03:15 PM Thread Starter
Motorcharge
cranks and doesn't start
post #5 of 6 Old 11-07-2008, 03:22 PM
JTruel
Sounds like the CPS is on the fritz (Crank Position Sensor) do a search, look at the symptoms and fixes of other members. Verify that is what yours is doing.
included a link to a CPS failure thread also
http://www.jeepforum.com/forum/f11/all-points-cps-622005/
good luck! keep us posted
2000 XJ Classic
2005 LJ
JTruel is offline
post #6 of 6 Old 11-07-2008, 03:40 PM Thread Starter
Motorcharge
yep, thats gotta be it, reading came out low.
thanks
anyone got a rough price on what these run?
cant seem to find it on google.
4.0 stalled on hard right turn, cranks but doesn't fire, no spark. Help fix it! johnsoninc86 XJ Cherokee Technical Forum 2 10-14-2009 05:13 PM
Has power, cranks, but won't turn over Flojo8000 XJ Cherokee Technical Forum 6 07-24-2009 11:27 AM
2001 Grand Cherokee 4.0 cranks will not turn over. GoldMine63 XJ Cherokee Technical Forum 5 04-24-2009 09:45 AM
87 Comanche cranks but wont turn over Ethox MJ Comanche Technical Forum 8 03-30-2009 10:06 PM
4.0 cranks for awhile before it will turn pfishe XJ Cherokee Technical Forum 8 10-25-2008 01:15 PM
