88 overheating problem - JeepForum.com
post #1 of 4 Old 12-24-2010, 01:44 PM Thread Starter
mannyawwad
2002 KL Cherokee
i have an 88 xj and it was overheating, i changed the thermostat and the water pump and then it worked good for about a month but then it started overheating again, please helppppppp
mannyawwad is offline
post #2 of 4 Old 12-24-2010, 03:42 PM
xjfever
xjfever's Avatar
1995 XJ Cherokee
Did you flush the cooling system? Did you remove all the air from the system? And are you using a 50/50 mix of anti-freeze and distilled water? Just some thoughts I had. I would also make sure the cap and bottle are sealing correctly. And when does it overheat, at idle/in traffic, or at highway speeds, or all of the above? The fan clutch is suspect if it overheats at slow speeds in traffic or at idle, and the electric fan should come on around 215* or so, and anytime the AC/defrost is selected.
xjfever is offline
post #3 of 4 Old 12-25-2010, 07:59 AM
rmack
check the cap on the burp tank for proper sealing.
rmack is offline
post #4 of 4 Old 12-31-2010, 08:06 PM
oldblackxj
1988 XJ Cherokee
Definately get a new cap for the coolant tank. I have had this problem for years. My solution was to get a coolant tank camp made for a Volvo. It will work!
oldblackxj is offline
xj
Overheating Problem '90 4.0L mattrendo XJ Cherokee Technical Forum 2 02-03-2009 07:00 PM
Please help. overheating problem. huntking24 XJ Cherokee Technical Forum 2 08-24-2008 06:19 PM
Overheating problem Altec88 XJ Cherokee Technical Forum 4 07-26-2006 12:42 AM
A new overheating problem... I've had it. sociald XJ Cherokee Technical Forum 12 05-26-2005 03:37 PM
Overheating Problem XJ MONKEY XJ Cherokee Technical Forum 9 11-09-2003 12:00 AM
