88' coolant reservoir - JeepForum.com
post #1 of 12 Old 03-12-2012, 07:57 PM Thread Starter
beerto11
hey my cousin has an 88' cherokee 4.0l. (i have a wrangler) and he is having problems with the cap and also the tank for his coolant. he has replaced both of the 3 times but the tank cracks out and the cap gets warm and worps and doesn't seal anymore. just wondering if anyone else had this problem and what did you do to fix. all answers are greatly appreciated thanks
beerto11 is offline
post #2 of 12 Old 03-12-2012, 08:20 PM
RBxj
As far as I know everyone has or will have this problem. I have two 90 XJs and have converted them both to an open system. Either replace the radiator with a later model that has a fill neck, or install a fill neck in the top hose. Block off the pressure bottle and re-plumb it as an overflow tank or just get and aftermarket overflow.
RB
RBxj is offline
post #3 of 12 Old 03-12-2012, 08:40 PM Thread Starter
beerto11
i kinda figured that was the answer i was going to get lol. i'm trying to talk him into doing a radiator swap but he is kinda stubborn. i think we are going to fab a tank for it though. hopefuly we get it fixed. thanks for the info.
beerto11 is offline
post #4 of 12 Old 03-12-2012, 08:41 PM
keepishop
1989 XJ Cherokee
Part of the problem with the renix bottles is that the hood can put pressure on the cap and eff up the threads. Moving the bottle's metal shelf down a half inch can help. Using a volvo cap and bottle might work better as well. As a quickfix, a hose clamp around the car can squeeze (get it? ha ha...) a bit more life out of it.
Personally, I just converted to a full open system using a caravan coolant bottle and a 1991 radiator. The temp sensor for the efan is plumbed to the heater core hoses.
Current: Black 89 limited, dakota bastard pack, zj coils, 1.5" lift, open cooling swap,
Rest in Pieces: Red 1990 cherokee dana30/8.25 - v8 zj coils & s10 bastard pack 2.5" lift - 31x10.5r15 tires - v8 zj tierod
Originally Posted by talentjeep View Post
Bleed or Quit.
jf irc @ irc.freenode.net #jeepforum
keepishop is offline
post #5 of 12 Old 03-12-2012, 08:44 PM Thread Starter
beerto11
haha ya we actually have done that hose clamp before. this last time we tried to siliconed the entire cap on but that didn't work out as planned.
beerto11 is offline
post #6 of 12 Old 03-12-2012, 08:58 PM
keepishop
1989 XJ Cherokee
The cap is supposed to let air out, so I can see that being a less than great solution.
Bleed or Quit.
post #7 of 12 Old 03-12-2012, 09:17 PM
keane1234
I have the same problem i was wondering if a radiator for a 93 xj will fit with a radiator cap i have been looking at the specs they look almost the exact same anybody done this or have info bout doing this ???? Thankyou in advance
keane1234 is offline
post #8 of 12 Old 03-12-2012, 10:00 PM
keepishop
1989 XJ Cherokee
A 93 rad should fit. You may need to clearance the area around the neck for some brands of rad. I think mine was a koyorad and it fit with no mods. I'm running a 16lb cap on it.
Bleed or Quit.
post #9 of 12 Old 03-12-2012, 11:35 PM
Paradise XJ
1988 MJ Comanche
You can't just plop a 93 radiator in there without changing the SYSTEM. Search OPEN SYSTEM.
Get rid of the pressure bottle and the RENIX heater valve, put in an OVERFLOW bottle.
1990 XJ Laredo - White & Chrome
1988 MJ Pioneer - Metallic Green and Black
Paradise XJ is offline
post #10 of 12 Old 03-13-2012, 12:22 AM
keepishop
1989 XJ Cherokee
Actually, you can. It'd be kinda dumb since the weak link would still be the pressure bottle. But yes, just dropping in a 93 rad would be a complete functional cooling system.
Until the pressure drops and it sucks in air.
Bleed or Quit.
post #11 of 12 Old 03-13-2012, 09:29 AM
keane1234
yea i plan on adding a resevoir to it making a open system thanks guys
post #12 of 12 Old 03-13-2012, 09:46 AM
keane1234
Coolant in Vacuum Reservoir twmart XJ Cherokee Technical Forum 4 09-27-2010 06:21 PM
Coolant reservoir empty missyxj XJ Cherokee Technical Forum 10 12-02-2008 06:53 AM
Rust in the coolant reservoir wizardPC XJ Cherokee Technical Forum 7 04-17-2007 08:26 PM
01 Coolant Reservoir Gr8Swammee XJ Cherokee Technical Forum 6 12-17-2006 09:47 AM
Expansion reservoir - coolant trashman XJ Cherokee Technical Forum 14 03-06-2005 10:07 PM
