88 Cherokee will not idle - Page 2 - JeepForum.com
post #16 of 42 Old 05-14-2013, 05:22 PM
miceanic
1990 XJ Cherokee
I would suggest having someone jump start it. If it clicks before you hook it up and it doesn't click after then you know your battery doesn't have the juice needed to turn over our you can use a multimeter if you dont have an extra vehicle laying around to see how much charge it is holding.
miceanic is offline
post #17 of 42 Old 05-14-2013, 06:25 PM
cruiser54
1990 MJ Comanche
Don't plug any holes. Just make sure your MAP line is plugged into the throttle body.
If you own a Renix Jeep, you must check this out:
My Jeep technical photos:
cruiser54 is offline
post #18 of 42 Old 05-14-2013, 06:43 PM Thread Starter
79chiefs
1988 XJ Cherokee
It does it if its jumped too, i tapped the starter relay and it starts, i guess that is the problem. It started acting up so i cleaned the contacts on it and it works, i ordered a new relay. I also am now tracing wires so i can fix my electrical issues. When i tried to test the tps though, it says i need a square connector with 4 wires to test the engine not to use the flat connector, my tps square connector only has 3 wires.
Would a bad map sensor cause misfiring at low idle, high rpm ,and hard starting ,and throttle issues, as in i only can get it to run if i pump it?
99WJ Laredo I6-A 2wd
88XJ-Building on a budget.
95 E34 540i-DD
79chiefs is offline
post #19 of 42 Old 05-14-2013, 06:51 PM
miceanic
1990 XJ Cherokee
Both connectors have three wires, the square one just has a spot for an absent fourth connection. Follow cruisers write up and see what happens.
miceanic is offline
post #20 of 42 Old 05-14-2013, 06:56 PM Thread Starter
79chiefs
1988 XJ Cherokee
Originally Posted by cruiser54 View Post
Renix Tips
I just noticed your Renix Refresh tips, i am going out right now and do #18 For my under dash ground. I love that thread. I will slowly be doing all of them, that is GREAT advice, thanks for taking the time for doing that. It is going to help me work the bugs out of this.
95 E34 540i-DD
79chiefs is offline
post #21 of 42 Old 05-14-2013, 08:06 PM Thread Starter
79chiefs
1988 XJ Cherokee
Well i just realized, if it is cold the starter does not give trouble, once its warm it will not work.
I just ordered new TPS, IAC, MAP, Wires, Starter, Plugs. I will see if that helps, and will replace rotor and cap when i can.
Also is the timing adjustable on this, my father asked me because it sounds like the timing is off because of the hard starts, and once it runs it starts spitting through the intake and kicking back and misfiring bad.
95 E34 540i-DD
79chiefs is offline
post #22 of 42 Old 05-15-2013, 06:20 PM Thread Starter
79chiefs
1988 XJ Cherokee
Well Map wires plugs, and another starter in. It turns fine now, but still no start problem. After new map no high startup. Have new tps, and iac. Am putting in iac now.
95 E34 540i-DD
79chiefs is offline
post #23 of 42 Old 05-15-2013, 06:27 PM Thread Starter
79chiefs
1988 XJ Cherokee
I need instructions on how to install the new TPS, i know it needs to be done just-right on the Renix, unlike the plug and play HO motors.
95 E34 540i-DD
79chiefs is offline
post #24 of 42 Old 05-15-2013, 06:27 PM
cruiser54
1990 MJ Comanche
Non adjustable timing. Do the ground refreshing and upgrades of the wires I gave part numbers for at Napa.
post #25 of 42 Old 05-15-2013, 06:30 PM
cruiser54
1990 MJ Comanche
Adjust it using the flat connector as if it were a manual transmission vehicle.
RENIX TPS ADJUSTMENT
Before attempting to adjust your TPS be sure the throttle body has been recently cleaned. It's especially important that the edges of the throttle butterfly are free of any carbon build-up.
IMPORTANT NOTE: With the Key OFF, and using the positive (red) lead of your ohmmeter, probe the B terminal of the flat 3 wire connector of the TPS. The letters are embossed on the connector itself. Touch the black lead of your meter to the negative battery post. Wiggle the wiring harness where it parallels the valve cover and also over near the MAP sensor on the firewall. If you see more than 1 ohm of resistance, or fluctuation in your ohms reading, some modifications to the sensor ground harness will be necessary. The harness repair must be performed before proceeding. I can provide an instruction sheet for that if needed.
MANUAL TRANSMISSION:
RENIX manual transmission equipped XJs have only a flat three-wire TPS mounted on the throttle body and it provides data input to the ECU. It has three wires in the connector and they're clearly embossed with the letters A, B, and C. Wire "A" is positive. Wire "B" is ground. Key ON, measure voltage from "A" positive to "B" ground by back-probing the connectors. Note the voltage reading--this is your REFERENCE voltage. Key ON, back-probe the connector at wires "B" and "C". Measure the voltage. This is your OUTPUT voltage. Your OUTPUT voltage needs to be seventeen percent of your REFERENCE voltage. For example: 4.82 volts X .17=.82 volts. Loosen both T-20 Torx screws attaching the TPS to the throttle body and rotate the TPS until you
have achieved your desired output voltage. Tighten the screws carefully while watching to see that your output voltage remains where it is supposed to be. If you can't achieve the correct output voltage, replace the TPS and start over.
Sometimes, after adjusting your TPS the way outlined above, you may experience a high idle upon starting. If that happens, shut the engine off and reconnect your probes to B and C. Start the engine and while watching your meter, turn the TPS clockwise until the idle drops to normal and then rotate it back counterclockwise to your desired output voltage.
AUTOMATIC TRANSMISSION: RENIX automatic transmission equipped XJs have a TPS with two connectors. There is a flat three-wire connector, same as the manual transmission vehicles have, and it is tested the same as the manual transmission equipped vehicles, as outlined above—FOR ALL ENGINE MANAGEMENT RELATED ISSUES.
However, the automatic TPS also has a square four-wire connector, clearly embossed with the letters A,B,C, and D. It only uses three wires and provides information to the Transmission Control Module. THIS SQUARE FOUR WIRE CONNECTOR IS USED FOR TRANSMISSION/SHIFTING RELATED ISSUES ONLY. Key ON, measure voltage between "A" positive and "D" ground. Note the voltage. This is your REFERENCE voltage. Back-probe the connector at wires "B" and "D". Measure the voltage. This is your OUTPUT voltage. Your OUTPUT voltage needs to be eighty-three percent of your REFERENCE voltage. For example 4.8 volts X .83=3.98 volts. Adjust the TPS until you have achieved this percentage. If you can't, replace the TPS and start over. So, if you have an automatic equipped XJ your TPS has two sides--one side feeds the ECU, and the other side feeds the TCU.
FOR AUTOMATIC TRANSMISSION RELATED ISSUES: Check the square four-wire connector side of the TPS.
If you have ENGINE ISSUES check the flat three-wire connector side of the TPS.
For those with a MANUAL TRANSMISSION--the TPS for the manual transmission XJs is stupid expensive. You can substitute the automatic transmission TPS which is reasonably priced.
Revised 09-22-2012
post #26 of 42 Old 05-15-2013, 07:19 PM Thread Starter
79chiefs
1988 XJ Cherokee
Now its adjusted, no surging idle thanks. My dad just looked at it, and he said its fuel delivery problem, guess i will pick up pressure tester tomorrow and prob. will have to drop the tank and clean the filter on the fuel pump, because the other filter is new, and most lines are new outside the tank.
95 E34 540i-DD
79chiefs is offline
post #27 of 42 Old 05-15-2013, 08:06 PM
cruiser54
1990 MJ Comanche
You're very fortunate to have a Dad who helps you.
post #28 of 42 Old 05-15-2013, 08:21 PM Thread Starter
79chiefs
1988 XJ Cherokee
He can't too much, he broke his neck in a few places, a few years back, and that is why i got into automotive he could no longer do it, i love it, my first was 92 cherokee and it needed a motor in it. He gives advice if i cannot figure it out. I love working on vehicles, especially JEEPS.
This twitchy Renix is kicking my butt though. But it will always leave me with something to do after school. And when i am bored.
95 E34 540i-DD
79chiefs is offline
post #29 of 42 Old 05-15-2013, 08:24 PM
cruiser54
1990 MJ Comanche
How cool!!!
post #30 of 42 Old 05-15-2013, 08:58 PM
miceanic
1990 XJ Cherokee
Haven't taken my fuel pump out yet but I know the filter is above the axle on the drives side and I'm pretty sure you can take the pump out without having to drop the tank.
miceanic is offline
