88 Cherokee will not idle - JeepForum.com
post #1 of 42 Old 05-13-2013, 08:34 PM Thread Starter
79chiefs
1988 XJ Cherokee
As the title states, also VERY hard to start, have to pump gas to started and keep running. I cannot hold it, i have to pump it. While it is cold if i let rpms get low sounding it bogs out or if they get high it bogs out. But once warm it will run just not idle with out pumping it.
99WJ Laredo I6-A 2wd
88XJ-Building on a budget.
95 E34 540i-DD
79chiefs is offline
post #2 of 42 Old 05-14-2013, 07:07 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
What have you done so far?
Are your intake manifold bolts loose or missing?
Hose from throttle body to MAP messed up in any way?
If you own a Renix Jeep, you'll want to check this out.
An index to over 30 write-ups can be found in the link below
My Jeep Technical Photos
cruiser54 is offline
post #3 of 42 Old 05-14-2013, 08:31 AM Thread Starter
79chiefs
1988 XJ Cherokee
I have cleaned the throttle body and replaced vacuum lines, i have to go buy more line thought. That line looks good, after i cleaned it with parts cleaner it ran better but had a surging idle. Replacing a few lines fixed that. But it tries to correct idle but does die.
95 E34 540i-DD
79chiefs is offline
post #4 of 42 Old 05-14-2013, 08:34 AM Thread Starter
79chiefs
1988 XJ Cherokee
No bolts are missing but there us a hole above the map sensor line on the intake, it had nothing in it so i plugged it. I think i still have a leak and will keep looking for it, but have traced all lines with a vacuum diagram and not found it. Could i just eliminate that vacuum tree thing and run the lines directly to their connection?
95 E34 540i-DD
79chiefs is offline
post #5 of 42 Old 05-14-2013, 03:05 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
You mean hole above the vacuum line on the throttle body?
post #6 of 42 Old 05-14-2013, 03:18 PM Thread Starter
79chiefs
1988 XJ Cherokee
Yes, it now has all new vacuum lines, it idles lower, but still stalls. It also has surging start up back. And it starts quicker now.
95 E34 540i-DD
79chiefs is offline
post #7 of 42 Old 05-14-2013, 03:20 PM Thread Starter
79chiefs
1988 XJ Cherokee
I am also have constant trouble with the starter clicking, then it will turn, then click click click, and turn. Lately it just clicks and once in a blue moon turn.
95 E34 540i-DD
79chiefs is offline
post #8 of 42 Old 05-14-2013, 03:25 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Bad battery, bad starter, bad cables, bad connections, bad grounds......
post #9 of 42 Old 05-14-2013, 03:36 PM Thread Starter
79chiefs
1988 XJ Cherokee
Starter rebuilt, it works fine i replaced it same, so i got my money back. I did a ground refresh as i read that might help. Battery is new. I cleaned all connections i could find as stated in the ground refresh thread i read. I will be getting new cables as these are 25 years old.
95 E34 540i-DD
79chiefs is offline
post #10 of 42 Old 05-14-2013, 04:00 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Good plan.
post #11 of 42 Old 05-14-2013, 04:08 PM Thread Starter
79chiefs
1988 XJ Cherokee
Now, about that hole i plugged is it supposed to be plugged? I read a thread on the IAC, pulled it and i could hardly get it out. It was frozen in with carbon build up. But in the diagram that explained how it worked, it showed an air passage, and that hole at the end of it.
95 E34 540i-DD
79chiefs is offline
post #12 of 42 Old 05-14-2013, 04:09 PM Thread Starter
79chiefs
1988 XJ Cherokee
On my throttle body there is two holes not 4, one has the vacuum line for the MAP sensor in it the other i plugged.
95 E34 540i-DD
79chiefs is offline
post #13 of 42 Old 05-14-2013, 04:10 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
I'm confused. What hole did you plug?
And with what?
post #14 of 42 Old 05-14-2013, 05:18 PM Thread Starter
79chiefs
1988 XJ Cherokee
Plastic plug from an old refrigeration unit.
It in the pic but without plug.
Replaced battery cables, put two new negatives for extra ground, and still starter clicking. Could it not be getting a charge to turn? As in a relay engaging the solenoid for the gear to move to the flywheel, but not for the motor to turn, if that makes sense.
95 E34 540i-DD
79chiefs is offline
post #15 of 42 Old 05-14-2013, 05:21 PM Thread Starter
79chiefs
1988 XJ Cherokee
http://www.jeepforum.com/forum/f11/8...m-leak-153902/
This tread explained it, i guess there is nothing in that hole.
95 E34 540i-DD
79chiefs is offline
