88 Cherokee random skipping/high idle - JeepForum.com
post #1 of 12 Old 07-12-2013, 05:01 AM Thread Starter
88jeepw
1988 XJ Cherokee
Need help. 88 XJ we have cleaned the throttle body, replaced the TPS, new plugs, wires, distributor cap and rotor, and new fuel filter. It seems that after driving 15 minutes or so it will start random skipping. Tonight we drove over
town pushed in clutch got a high rpm the only thing that seemed to bring down Rpm was Turing the a/c on. Got to destination. Idle was normal. Drove home started out good. Little way down the road random skipping again.
Any ideas what to do next?
88jeepw is offline
post #2 of 12 Old 07-12-2013, 05:41 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Did you adjust the new tPS?
If you own a Renix Jeep, you must check this out:
My Jeep technical photos:
cruiser54 is offline
post #3 of 12 Old 07-12-2013, 11:23 AM Thread Starter
88jeepw
1988 XJ Cherokee
Yes we printed off the instructions and followed that. Thanks.
88jeepw is offline
post #4 of 12 Old 07-12-2013, 02:56 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Did you check it on the flat 3 wire connector or the square 4 wire connector? Did you do the sensor ground test beforehand?
post #5 of 12 Old 07-12-2013, 04:49 PM Thread Starter
88jeepw
1988 XJ Cherokee
We did the test on the 3 wire connector and he did do ground test. Thanks for your help. All help is appreciated.
88jeepw is offline
post #6 of 12 Old 07-12-2013, 05:32 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Define "skipping".
post #7 of 12 Old 07-12-2013, 05:57 PM Thread Starter
88jeepw
1988 XJ Cherokee
You can be going along fine and all of a sudden it will skip (misfire). An occasional miss when not in a pull.
88jeepw is offline
post #8 of 12 Old 07-12-2013, 07:00 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Like a total cutout? Not just a single cylinder miss?
You have an 88. Ever do the C101 cleaning or ground refreshing and connector refreshing?
If not, click on the link below and see posts 1,2,3, and 4.
http://www.cherokeeforum.com/f51/cru...x-tips-153657/
post #9 of 12 Old 07-12-2013, 07:09 PM Thread Starter
88jeepw
1988 XJ Cherokee
Not really a total cut out. Tonight we plugged the EGR valve drove for about 30 minutes or so no problem. Will drive it more tomorrow. Also will look at the grounds. Thank you so much for your help. Will try these things and repost.
88jeepw is offline
post #10 of 12 Old 07-12-2013, 07:11 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
How did you plug the EGR? Just the vacuum line?
post #11 of 12 Old 07-12-2013, 07:29 PM Thread Starter
88jeepw
1988 XJ Cherokee
Yes just the vacuum.
88jeepw is offline
post #12 of 12 Old 07-12-2013, 08:13 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
See how that works. In the meantime, REFRESH the grounds. Don't just look at tehm. The other procedures can reap benefits as well. Eliminate known issues.
