87 XJ fuel pump gets loud after extended driving - JeepForum.com
post #1 of 4 Old 01-18-2014, 11:19 PM Thread Starter
BlackBeattyXJ
hey everyone, this is my first post so forgive me if I come out with a billion questions. But for starters I have a 1987 Cherokee with a 4.0 renix and aw4 trans. When I first turn the key to the on position I hear the pump cycle and it sounds fine, and when I start it up its nice and quiet, and will be if im just driving around town. if I drive for more than an hour non stop (especially if its hot) the pump starts to whine really loud likes its struggling or being fed to much power. I have yet to replace the filter or regulator or relay and I just wanted an opinion on what the best course of action would be.
BlackBeattyXJ is offline
post #2 of 4 Old 01-19-2014, 06:51 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
My guess is that the pump is dying.
As with any "new to you" vehicle, I would replace the fuel filter along with doing a bunch of cheap and simple checks before driving it alot.
Check every lube level and condition. Look for leaks.
Grease every zerk on it and check for loose u-joints.
Inspect the brake pads and shoes.
You get the idea.
If you own a Renix Jeep, you'll want to check this out.
An index to over 30 write-ups can be found in the link below
My Jeep Technical Photos
cruiser54 is offline
post #3 of 4 Old 01-19-2014, 06:54 AM
tjwalker
It's the crank sensor!
tjwalker's Avatar
That's my guess to. Best to replace it when can control the repair than to have it die on you at the most inopportune time.......
A fresh fuel pump and filter and also a complete tuneup and replacing all fluids always a good idea for a "new-to-you" vehicle.
Enjoy your XJ!
99 Cherokee, 4.0 AW4, NP242
Past Jeeps: 49 Willys, 81 Scrambler, 88 Comanche
Without "data", all you have is an opinion!
tjwalker is offline
post #4 of 4 Old 01-19-2014, 09:58 AM Thread Starter
BlackBeattyXJ
thanks for the replies guys, but damn, well I guess it would be best to replace it now then be stuck somewhere. any suggestions on what pump is best? the nearest auto parts store is autozone and they sell only airtek and ive had really bad luck with them
